cjr1's Avatar
Question Black RTV on thru-bolts?
All info says to use black rtv on case thru-bolts@ o-rings.I can't seem to find this.I admit I haven't looked very hard,but the question is....I found "Loctite Superflex Red High Temp RTV" #59630.We use this on pipe flanges & other high temp/pressure applications @ work.It is a silicone adhesive sealant,listed up to 600deg.F.Would this be an ok substitute for the black stuff?What is the rating for the black?
Any thoughts?(dumb ?)
Thanks,getting ready for assembly....
Chris
"If you think it's gonna cost $1000, ya better budget for $2000."
Chris
85 Carrera 3.2(Back on the road after rebuild)
02 Trans Am WS6
95 Eagle Talon
98 Bravada(sold)
07 G5
Old 08-25-2005, 08:46 AM
Unregistered
sammyg2's Avatar
Yup, it will work just fine as long as it is oil resistant which I believe it is.
The O-rings are supposed to do the sealing, the RTV just helps out a little.
BTW, I would be surprised if a FLAPS exists that doesn't have black RTV. That stuff is everywhere around So Cal, maybe that is due to the type of maintenance routinely performed by some folks who live here
They had to put up signs in the pep boys parking lot telling people not to change their oil or drain it on the ground in the parking lot, in english and spanish! I find that amusing and disturbing at the same time.
The super blue will work fine also but might not be as visually apealing.
Old 08-25-2005, 09:44 AM
cjr1's Avatar
Cool
Thanks Sammyg2,
I haven't really looked for the black rtv,the red was available @ work=free!
BTW,I know what you mean about the stuff people do in the parking lots of parts stores!It gets a little nasty in some.Can't even get out of your car without stepping in someones mess.
Looks like an outdoor swapmeet sometimes!They just don't care about anything......SAD!
Chris
Chris
02 Trans Am WS6
95 Eagle Talon
98 Bravada(sold)
07 G5
Old 08-25-2005, 05:25 PM
89red911's Avatar
i found that permitex makes and anerobic rtv. Its a clear red rtv works great with high temp stuff it never gets hard it for the most part stays the same as it came out of the tube i have never had a problem with i use it on all the ferraris and porsches i work on
Shiny side up, Rubber side down, Its the fastest way around the track.
Old 08-25-2005, 06:25 PM
Irrationally exuberant
ChrisBennet's Avatar
Also know as Loctite 518. Seals bigger gaps than 574 too. I used to use it to seal the cam carrier to the heads.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 08-26-2005, 11:13 AM
89red911's Avatar
Exclamation rtv
just a note
i found that loctite split and some of the pruducts that they used to sell are no longer available. I know that in the few manuels i have they sight part numbers for loctite pruducts that are no longer.
This is the main reason i switched to the permitex anerobic gasket maker. like i stated in earlier posts it has worked great for everything i have used it on
they even have a spary that is used to prep the surfaces to be sealed. I have used it both ways with and without.
it seams as long as your surface is clean and free of oil and other crap it works great.
Old 08-26-2005, 11:48 AM
Re: rtv
just a note
Yeah, I call it Loctite 518 but like you said, it comes in a Permatex package now.
Permatex Item No 51813 (emphasis added)
On the back it reads: Manufactured by Loctite Corporation
And you're right, it does work great. I just use ThreeBond instead these days.
-Chris
P.S. Anyone know if the Audi transmission sealant is repackaged 3Bond 1211? Sure looks like it.
Old 08-26-2005, 11:57 AM
89red911's Avatar
i just heard from ly local parts house that loctite is on the block to be sold. from what i was told it will be divided and sold to several companies
has any one else heard this
Old 08-26-2005, 08:27 PM
