Anybody have ID for this part #
You can save me some time.....not having to put a case back together to check the ID of the main bores. I've got a sneaking hunch this is first over OD.
PN on the bearing half is 901.132.60.
JPIII Early Boxster Last edited by J P Stein; 08-20-2005 at 04:04 PM.. |
Hi JP,
My Pet shows a part number 901-101-132-60 as being "bearing shells II-VII". It is listed as part of part number 901-101-901-60 "Set of Crankshaft beraings, oversize 0.25mm outer" Hope it helps buddy.
Thanks, Harry
I'll bet my PET woulda showed that if it were not MIA. Now....if I could just find a decent price on the things, I'd consider rebuilding this 2.7L....just for the hell of it.
JPIII Early Boxster |
JP,
Are you talkin' 'bout your 2.7! I thought is wuz healthy. FWIW, I'll miss ya at the next AutoX. Do a few runs for me. Shame, as I am finally gittin' new shoes for my gal..... Theys shud be on next Tuesday....
No, mines OK.
This was a free flood motor......it needs *some* work.
Warren Hall Student
EBS has .25 over for $115. That's only $30 more than standard.
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
I just went through this today for my 2.7 I had it line bored 1st over (.25) everything except #8 so here are the Part #'s assuming the crank is Standard:
901.101.131.60 (x2) 901.101.132.60 (x12) Good luck!!!
Brent Wittke _______________ '67 911 to '73 RSR conversion '88 911 Cab '02 Boxster |
