Kolibri
blackbird225's Avatar
2.2T - 2.4T Conversion advice needed
I have a 70T engine with these parts ready for Wayne's 2.2-2.4 higher compression engine.
  • recently new T pistons with machined valve reliefs ( from Walt )
  • Nice std 2.4 Crank / Rebushed 2.4 Rods
  • New Main Bearings
  • 12 Refaced or New Rocker Arms ( Walt )
  • New E-Cams ( Reground by Camgrinder )
  • Rebushed/Rebuilt Zenith Carbs
So, I am wondering about 3 of the next steps. I know that I need to get the heads done. I know that I should get new exhaust valves, but do I reuse 35 year old intake valves and springs, or add those to the pile? The Intakes are within the clearance ranges.
My case does NOT have piston squirters or the oil-bypass surgery. How critical is this to do, and can someone recommend a reasonable machine shop to do it?
Just any advice for this particular upgrade would be helpful.
Michael
69T Roller
1942 VW Kübelwagen
1940 Zündapp KS 600
1941 Zündapp KS 750
1975 Volvo C303 TGBII
1967 Honda S90, 1975 CB550
Old 08-21-2005, 06:24 AM
fancytown
I re-used a lot of my intake valves and springs.A T-engine doesn't see a high-revving life. Use your best judgement, and that of your "Porsche" machine shop as advice. As for case squirters, personally, I'd say yes. Are you going to DE the car? If so, temps will get up there. Not just oil temps, but intenal temps. This is something that will extend the life of your engine. Heat kills.
I used a local guy to Chicago, so I can't comment on machine shop.
Good luck....beautiful car!
all cars sold.
Old 08-23-2005, 05:19 PM
Kolibri
Hey, I know that I SHOULD know this, but what does DE mean?
Michael
1942 VW Kübelwagen
1940 Zündapp KS 600
1941 Zündapp KS 750
Old 08-23-2005, 06:28 PM
Warren Hall Student
Bobboloo's Avatar
DE = Drivers Education
When you get the heads done the shop will let you know which valves are reusable. They can also test your springs to see if they are within spec.
Inre: your case. I don't know the machine shops on the east coast but Ollies out here has tons of happy customers. Me included.
That is a beautiful car. I love the T trim. It would make a great bookend for my Signal Orange Targa. If ever you decided to part with it put me first in line. Seriously.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 08-24-2005, 12:10 AM
