Replace just the voltage regulator? (1984)
My '84 has had a rebuilt valeo alternator that has the usual problems of suddenly supplying massive voltage increasese in spikes. We never had much luck with the rebuilt valeos, but I am a little squeamish about parting ways with $500.00 at this time since the car won't be driven much for a while after the engine goes back in. Has anyone ever tried replacing just the voltage regulator? Pelican lists it as such;
Voltage Regulator, internal type, 911/911 Turbo (1982-89) |
You could just replace the voltage regulator but I think that once you get the old one out you won't like the looks of the armiture. They usually are grooved pretty deep from the voltage regulator brushes. Your best bet is to just bite the bullet and get a new Valeo unit. (not rebuilt)
Dan 2002 996 C4 Cab w/ Jake Raby 4.0 2024 Tacoma TRD Offroad 4x4 2003 Range Rover HSE |
I know that there is a good shop in my area that only rebuilds alts and starters. YOu may want to see if such a shop is near you. I have found that small shops that do these rebuilds give you back a new quality part for alot less. just a thought
Shiny side up, Rubber side down, Its the fastest way around the track. |
