I like Orange
Cookie Porsche's Avatar
Question Gearbox for 911 Turbo Racecar ?
Hello,
As you may have seen we're building a Turbo engine for our racecar. NOW we need a gearbox. We need 5 gears and it must be able to handle 400+ rwBHP.
1) Do I need a G50 (too heavy!).
2) Can a 915 5-speed be modified to handle this power on track?
3) Is there any NON-PORSCHE (yirk) boxes available, maybe even sequential types?
4) What clutch setup do you recommend. Will it fit the standard SC / 915 flywheel?
4-speed is for tractors, too limited. I think the G50 is too heavy.
Regards, Tom
“Rules are meant to be interpreted…”
http://www.cafe9.co.za
Old 08-30-2005, 09:23 AM
beepbeep's Avatar
Re: Gearbox for 911 Turbo Racecar ?
Originally posted by Cookie Porsche
Hello,
Hello!
Well, it's a 5-speed Porsche transaxle...a fairly good one.
No, not in reliable fashion.
Yes, Hewland makes nice transaxles...they cost a lot. You might find used ones somewhat cheaper.
Standard SC/915 flywheel is too small, you should step up to 240mm clutch.
Well it's your opinion. 917/30 and 935 had 4-speed transmissions. If you find G50 too heavy just call Hewland and open up your wallet.
Regards, Tom [/B]
Thank you for your time,
Old 08-30-2005, 05:47 PM
WydRyd's Avatar
Fit a G50 and lose weight elsewhere! The G50 will handle anything you throw at it
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 08-30-2005, 08:40 PM
I like Orange
Well, hrmmph...
If I go the G50 route should I just change 3+4+5 to lower ratios - no sense in changing 1+2 with that kind of power...
OR WHAT SAY YOU?
I currently run a GT LSD diff in my 3.8/915 combo - anyone with ideas for the Turbo/G50? same?
Merv; If you saw my current car it will be difficult to remove weight on the pack - unless I leave the car unpainted...
What clutch for the G50? WIll the RS pressure plate (light weight) and a button-clutch hold the Turbo?
Tom
Old 08-31-2005, 02:35 AM
Addicted to Racing
edbaus's Avatar
If this is a race only car, what do you need a first gear for. Put a first gear on a 930 trans that is more like a second gear, then shorten the others up as well (lengthen 2nd, maybe 3rd stays stock)
It is a little more for the custom main shaft and the car will not autocross very well, but for track work what do you need a first gear for.
I should take my own advice.
Ed Baus
GT4s
Old 08-31-2005, 05:53 AM
I like Orange
So true - very good advice....
But a 930 4-speed will cost almost the same as a G50, or not?
And the clutch setup on the Turbo 915 weighs like a ton (+/-)?
Also a bit tired of shifting the tractor g/box from the 1960's....
My current 915 runs almost 65mph in first so I really like that idea - rolling starts only.
Tom
Old 08-31-2005, 06:11 AM
Addicted to Racing
edbaus's Avatar
Assuming early car (torsion bar car)
the torsion bar tube gets in the way of the g50. So, you either need to have the g50 modified to have a shorter length (money) or (if you are not running torsion bars anymore) have the center section of the tube cut out and a loop bridged over the trans to retain stiffness.
Ed
Old 08-31-2005, 07:27 AM
Addicted to Racing
edbaus's Avatar
Oh, money on the 930. I got a 930 with limited slip. in as used condition for $1500. I will go through it myself, but all in all not a bad price. The prices I have seen on the g50 have been about that for a non lsd unit.
Ed
Check out the parts for sale:
http://www.demonspeedmotorsports.com
PCA National & NASA Instructor, NASA GTS & PCA GT Class Racer.
See my list of current cars in my garage.
Old 08-31-2005, 07:28 AM
I like Orange
Ed,
Thanks. No torsion bars - it's a race car and everything is cut out - I can fit almost anything in there! (Car is running 993 multi-link suspension and no tube/rear seats, etc.).
Were do you suggest I look for the 915/G50? I was quoted some $2200 without LSD! $1500 sound alot better.
Regards
Tom
Old 08-31-2005, 08:30 AM
KobaltBlau's Avatar
If the car is running 993 multi link rear suspension, you must have that ring frame (that the links attach to) back there as well. in this case, it would be a pain to fit a 915 or 930 box, I think. The G50 should be easiest to fit with the 993 subframe, and you won't get a hewland set up for near the same price. G50 makes the most sense for you, you could even do a 6-spd G50.
Andy
Old 08-31-2005, 09:18 AM
KobaltBlau's Avatar
what's the latest?
Andy
Old 09-05-2005, 09:46 AM
I like Orange
Andy,
In between building the car I take breaks to make money (!).
I may have located a G50 (from a 3.2) locally and will go check it out. Seems the way to go and this is the earliest G50 around - hopefully it is smaller than the later types?
Is there any pros or cons btw the different G50 boxes?
As you mention I have the 993 rear subframe in my car, but all mountings are new (car was a 72!). Currently running a very trick 915 but this will not handle a Turbo as mentioned above.
I would change some ratios and of course fit a LSD. Any other mods????
Thanks. Tom
Old 09-05-2005, 10:13 PM
Send a message via AIM to air-cool-me
just a thought... what about a trans from a 993? you have the multi-link... that sounds like a large project...
just thinking outloud about something i know nothing about..
-nick
SWB
Old 09-07-2005, 09:44 PM
I like Orange
Nick,
The 993 suspension (multilink) is independent from the engine and box - so I can fit anything. Currently running 3.8 + 915 but now I am going Turbo and would like a stronger box.
915 4-speed seems a step backwards. G50 early version is smaller than the later 6-speed (i.e. lighter). Since I'm changing ratios any G50 should do.
ANYONE with suggestions as to what to do to my G50? Differences btw the various G50's?
There must be plenty IQ out there....
Regards
Tom
Old 09-07-2005, 10:24 PM
beepbeep's Avatar
G50/52 is most desireable one. It was fitted to turbocharged cars and can withstand very high torque numbers (I know of one fitted to 800Nm TT 3.6 engine that survived lot's of dragracing and a trip to Nürburgring).
At very high power, OEM clutch diff isn't enough and it's best to fit Quaife mechanical differential.
Old 09-08-2005, 05:28 AM
WydRyd's Avatar
Tom
Tom, I have this same dilemma. Your best option for the G50 is either a Spec Stage3+ Clutch kit, or a Kennedy Engineering kit, with 930 Spring Centred Disk.
These will hold upwards of 600lb/ft of torque
Merv
'89 911 Turbo Cab
Old 09-08-2005, 06:37 AM
KobaltBlau's Avatar
The 993 suspension (multilink) is independent from the engine and box ...
is it really? I mean, does the trans crossmember mount to the car and not touch that subframe at all, even on a "real" 993?
Andy
Old 09-08-2005, 01:40 PM
I like Orange
Yep. Totally independent.
That's why it is such a lovely mod for a race car. Too involved for a street car.
I'm not having much feedback on the choice of G50 though - were are all the gearbox experts?
WydRyd. Tell me about the Spec Stage3+ Clutch kit, or a Kennedy Engineering kit - never heard about them...
Regards
Tom
Old 09-08-2005, 10:35 PM
