Piston Squirters
Hi Guys,
I would like to know where to get new piston squitrers. Mine were damaged when I rebuilt my motor last year. I managed to make a plan in a hurry to get the car on the road. I will be doing a strip & check of the motor at the end of the year, and would like to replace them. I have not been able to find them on this site. Please help!!!!! |
Direct from Porsche? Don't worry, they are cheap!
Merv '89 911 Turbo Cab Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition ![]() |
Do you have a part number?
Sorry I don't. Send an e-mail to your Porsche Spare Parts Centre and ask them directly I guess.
Wayne's book has the p/n's:
911.101.011.01 And Pelican sells them: they're called "Valves" in the Pelican store, rather than "Squirters".
1980 911SC - 2nd Rebuild in Process - 2005 Porsche Cayenne Turbo - 2013 VW R ________________________ 2000 BMW X5 - 1996 BMW 530i - Toy 4 Runner (x2 or 3) - 1987 Toy Supra - 1988 Honda Si - 1984 El Camino Super Sport - MGA - MGB - Fiat 124 Spyder - Fiat 128 Wagon - 1962 Karmann Ghia - 1951 VW - 1953 Willys Jeepster w/Chevy 286 - 1995 Volvo 960 - 2006 VW GTI |
Thanks guys,
I got the part numbers for the 911 & 930. Just wanted to know what the difference between the 911 & 930 piston squirters are. Wayne should also add the name squirter to the description, so that they can be found in a search of this site. Thanks again. |
I have two add my own .02 cents here, they or really a kind of pop off valve the name "squirter" I find miss leading because to me it implies an orface, which is not the case they our a spring loaded device that requires so much pressure before they release oil to the pistons, You can not block the oil passages with your fingers and use compress air ,to much pressure ,and you certainly can not just squirt carb cleaner through them. This info cost me $77.00
Addicted to Racing
OK, so you drill a hole the right size into the oil galley, put the squirter in place. Then what, peen the outside over to trap the squirter in the hole?
Thanks Ed
Check out the parts for sale: http://www.demonspeedmotorsports.com PCA National & NASA Instructor, NASA GTS & PCA GT Class Racer. See my list of current cars in my garage. |
Addicted to Racing
Bill,
Very nice illustration. Where did it come from. Ed
Shop manual, can't remember which one SC/Carrera/964/993 they are all the same wrt this operation.
The valves do have different ratings.
Addicted to Racing
Can anyone tell me from their experience if the port that follows back to the oil journal is a constant diameter, or is there a counterbore so that the oil squirter sits on a land.
Thanks Ed
