KevinG's Avatar
Distributor Rebuild Help
I posted this question earlier on the main board, but didn't get much response. Thought I would try again here.
I need to get my early S distributor rebuilt, and need recommendations on who to send it to. Local would be best, but not a requirement (Ventura County). Dizzy is an early S mechanical advance from a 2.2l.
Thanks for the help!
Kevin
1972 T Targa
Old 09-14-2005, 08:09 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Supertec Performance
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 09-14-2005, 06:30 PM
KevinG's Avatar
Thanks, Henry
I didn't know you guys did distributor work too. You did such a great turnaround on my injectors, how can I resist sending you my distributer as well?
Do I need to remove my optical trigger before sending it?
Just noticed you have moved to Fallbrook. I spent 8 great years there from 1990-98. Too bad I didn't have my PCar then - there's some great roads in the East County.
Kevin
1972 T Targa
Old 09-15-2005, 10:22 AM
Go ahead and sent it as you run it.
You're right about the roads. I could spend all day running back and forth on the road to Deluz. 2nd and 3rd gear corners, altitude changes and good secluded straights. What could be better?
Henry Schmidt
Ph: 760-728-3062
Old 09-15-2005, 11:41 AM
