Distributor Rebuild Help
I posted this question earlier on the main board, but didn't get much response. Thought I would try again here.
I need to get my early S distributor rebuilt, and need recommendations on who to send it to. Local would be best, but not a requirement (Ventura County). Dizzy is an early S mechanical advance from a 2.2l. Thanks for the help!
Kevin 1972 T Targa |
Try not, Do or Do not
Supertec Performance
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Thanks, Henry
I didn't know you guys did distributor work too. You did such a great turnaround on my injectors, how can I resist sending you my distributer as well? Do I need to remove my optical trigger before sending it? Just noticed you have moved to Fallbrook. I spent 8 great years there from 1990-98. Too bad I didn't have my PCar then - there's some great roads in the East County.
Go ahead and sent it as you run it.
You're right about the roads. I could spend all day running back and forth on the road to Deluz. 2nd and 3rd gear corners, altitude changes and good secluded straights. What could be better?
