speedingbullitt's Avatar
piston squirter pictures
I just got a 7R case and was looking at the piston squirters. It looks as though they may have been changed at some point in the life of the case. Some are recessed 2-3 mm and one is 2-3mm above the surface. The area surrounding the squirters has been peened over in some areas and some metal has actually been chipped away. Does anyone have any pics of properly installed squirters? I want to replace them during the rebuild and I am afraid some of the surrounding areas will break off leaving little "meat " left. My understanding is that they are an interference fit and are installed with loctite? Am I correct?
Steve Benitz
Old 10-18-2005, 02:12 PM
Irrationally exuberant
ChrisBennet's Avatar
The metal of the case is also dented ("staked") around the hole to keep the squirter from coming out.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 10-18-2005, 04:58 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Aluminum cases have dimples, mag cases do not have dimples from the factory.
Aluminum
Magnesium
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 10-19-2005, 10:47 AM
Henry,
Thanks for the pics! The case I have (7R) was dimpled and in the process some of the magnesium was chipped off in different areas. It generally looks like they were improperly installed. Most are below flush but some squirters are above the surface by a few mm and some are even installed crooked. Any thoughts?
I am going to pm you on a future project though....thanks for the help as always!
Regards
Steve Benitz
Old 10-19-2005, 12:52 PM
Tags
squirter
