Gon fix it with me hammer
svandamme's Avatar
lower pressure when hot
hi guys ,
this has me stumped
i had my engine ready to rebuild, but at the last moment , i decided to have it rebuilt by a shop specialized in early 911's
and mostly raced and rallyed 911's
now , Waynes book and Bruce Anderson both say that if you machine the bypass modification
then you need the newer plunger and longer spring
or there will be low oil pressure problems
the rebuilder said , nah , just the plunger , not the longer spring
now my rebuild is breakin in nicely , and my oil pressure cold is fine, just like before the rebuild
as soon as the engine is getting hotter, when it gets near 100 degrees, i notice a drop in oil pressure
my pressure gage is a 0-2-4-6-8-10 one
at idle , 1000 rpm , cold it reads 2+
hot , it hoveres smack in the middle of 0 and 1, with the oil warning light almost coming on ( slight flicker )
revving the engine , cold it goes up to 8
hot , it barely makes 6
before the rebuild , it went higher, even when hot
i have no front oil cooler, and i'm running 5w40 shell ultra
would this be a problem with the relief spring? should i put in the longer one ?
or would this be a problem with the oil weight? 100 degrees is smack in the middle of my gauge (150 is max ) so i kind of doubt that the oil could cause this at this temp...
any suggestions?
Stijn Vandamme
BIMDIESELBMW116D2019
Old 09-07-2005, 09:55 AM
rw7810's Avatar
Those levels actually sound right on. Same as mine on a year old build. Common for pressure to go low at hot idles. A 6 is 6 bar or about 90 psi.
Robert Williams
70' 911T
Old 09-07-2005, 11:15 AM
svandamme's Avatar
it still worries me , the idle pressure is really low, and before the rebuild , it did never go that low , not even when it was hotter than i've gotten it after the rebuild, and even when going near redline, it does not go above 6.
we drove an 86 Carrera today , that one has the front oil cooler , and we drove it till it was plenty warm (it was hotoutside as well ), and that one still goes to the 8 mark ( there's no markings on that gauge, but the same mark where mine would have an 8. it never goes below the 2 mark , even when idling... and that is how mine behaved before the rebuild and bypass modification... am i beeing paranoid about this??
Stijn Vandamme
Old 09-07-2005, 11:32 AM
First the oil pressure relief spring will likely only open at higher revs,so it isn,t likely the source of low pressure at idle it could explain a lower than normal high speed pressure reading. If you have the same weight oil in the engine before and after a rebuild and pressure is slightly lower at idle. It could be a result of regrinding the crank and fitting the bearings a little looser than before. I would discuss it with the shop that rebuilt it and see if they think it could indicate a problem.
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 09-07-2005, 01:42 PM
Nitrometano's Avatar
1bar equals to 15 psi.
1972 911T
1991 Mazda RX-7 Turbo II
Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life!
Old 09-07-2005, 01:59 PM
89red911's Avatar
I found my oil pressure to be lower hen i used thiner oil. you could try to put in some thicker oil like 20/50 thats what im using in one of my cars and it works great i have also found that some oils thin out more than others when hot. just a thought
Shiny side up, Rubber side down, Its the fastest way around the track.
Old 09-07-2005, 04:54 PM
svandamme's Avatar
i'll also try cam oil feed restrictors
Stijn Vandamme
Old 09-08-2005, 12:28 AM
The 86 Carrera's I had both had senders that were 100 PSI max. The car you have has 150 PSI max. The needle will be higher on the Carrera guage than on your car.
-Andy
Old 09-08-2005, 07:28 PM
svandamme's Avatar
installed the restrictors today
when hot now, the pressure indicator stays a at a more confidence inspiring level now... so i'm a happy camper
Stijn Vandamme
Old 09-24-2005, 09:28 AM
