hillelson1's Avatar
Send a message via AIM to hillelson1
engine stand
does any one have or no where i can get a cheap engine stand for a porsche 911 engine
thanks
-larry
Old 09-20-2005, 05:55 AM
dweymer's Avatar
it's the adapter(yoke) that's pricey; any regular stand will do. The porsche tool P201 engine yoke will allow you to split the case while on the stand without causing undue stress on the case.
Donnie
Currently Porsche-less.....
Old 09-20-2005, 07:30 AM
MBruns for President
JeremyD's Avatar
I bought an engine stand from Sams - goodyear model... it was like $56.00 and folds which is nice. I also wanted one that had 4 wheels on the ground.
Yoke from "mainlybydesign" Although I recommend this being spaced out another inch or so.
Old 09-20-2005, 09:01 AM
dweymer's Avatar
Jeremy, can you split the case with that one? I never found out and ended up buying the p-tool.
Donnie
Old 09-20-2005, 09:42 AM
JeremyD's Avatar
yep -
http://www.mainelycustombydesign.com/enginecomponents.htm#enginestand
Only thing I'd recommend is spacing it out a little further... I have about 4" spacers that came with the regular engine stand. I'd recommend at least 6" between the mounting surface and the surface of the engine stand (yellow part)
Old 09-20-2005, 09:48 AM
dweymer's Avatar
d&mn, coulda saved a hunk o' money
Donnie
Old 09-20-2005, 09:52 AM
