engine stand
does any one have or no where i can get a cheap engine stand for a porsche 911 engine
thanks -larry |
it's the adapter(yoke) that's pricey; any regular stand will do. The porsche tool P201 engine yoke will allow you to split the case while on the stand without causing undue stress on the case.
Donnie Currently Porsche-less.....
MBruns for President
I bought an engine stand from Sams - goodyear model... it was like $56.00 and folds which is nice. I also wanted one that had 4 wheels on the ground.
Yoke from "mainlybydesign" Although I recommend this being spaced out another inch or so.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Jeremy, can you split the case with that one? I never found out and ended up buying the p-tool.
yep -
http://www.mainelycustombydesign.com/enginecomponents.htm#enginestand Only thing I'd recommend is spacing it out a little further... I have about 4" spacers that came with the regular engine stand. I'd recommend at least 6" between the mounting surface and the surface of the engine stand (yellow part)
d&mn, coulda saved a hunk o' money
