LinkBack Thread Tools Rating: Thread Rating: 1 votes, 4.00 average.
Originally posted by Lukesportsman
K:
I'm going with GT20's. How many rpms and what boost target are you shooting for in the end? Aren't the GT25's getting pretty big for a 3.0 (pure question and nothing meant)? Twin plugging would be MORE important without intercooler. Depending on compression, piston shape, bore size and rpm twin plugging could make sense.
Boost treshold would be 2500-2700 rpms according to reliable info. So I suppose I´ll get my self a intercooler then. We just got a huge one from a Scania truck.
K
KH
964 C2 -90
9-3 1.8t -06
sold
911 3.2 -74
Old 12-16-2005, 12:46 PM
Try not, Do or Do not
Henry Schmidt's Avatar
A quick update
I thought you guys might get a kick from this email.
"Thought I would let you know first. It looks like we are making about 348 RWHP at 1 bar on 91 octane pump fuel. Just a heads up.
We plan on putting in some high octane fuel and running about 1.1-1.2 to she what she'll do., keep you posted."
Bryan .......
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 06-15-2006, 11:39 AM
iamchappy's Avatar
Henry, is it possible to use the intake and cis from the 930 3.0 and use it on my 79 sc 3.1 engine in place of the plastic airbox, will it bolt up.
914 6 Turbo twinplug 3.12
87 924S
Lexus SC400
Lexus LS400
Old 06-15-2006, 03:18 PM
Originally posted by Henry Schmidt
I have a 914-6 turbo header and intercooler for sale. If you might be interested I'll post pictures.
Do you still have pictures of the 914-6 turbo header and intercooler? Can you post them? Thanks
Old 06-15-2006, 04:01 PM
beepbeep's Avatar
K:
I recomend using twin GT17's if you want quick response. They are used in new SAAB 9-5's up to 180hp.
Boost treshold is ~1700 RPM on 2.3 engine. Interpolate the results with your volume and you will get approximate treshold +- 5% (depending on headers and ignition timing)
They are fairly inexpensive and quite small. Internal wastegate is a plus, less hassle with external ones.
Thank you for your time,
Old 06-16-2006, 03:23 AM
rsrfan's Avatar
Great numbers Henry. I bet she really scoots.
JP
JP
86 930/4 tribute beasty
81 sc beach beater
‘55 Belair
‘40 Ford pickup
Old 06-16-2006, 09:10 AM
A 3.0 turbo intake will fit an SC.( better on a late 3.0 80-83 than an early 3.0) I believe I have enough parts to duplicate the system in Brian's car. All you need is $$$$$$
BTW: I think your engine is a 3.16. Just like a few of the earlt 935 engines
Henry Schmidt
Ph: 760-728-3062
Old 06-16-2006, 10:31 AM
typ 911
Bryan Beaumont's Avatar
I thought I would give a quick update to what has been going on with my car. I decided to intercool the car. The primary reason was to keep it cool and a little added insurance. If I gained a few HP in the process than that would be cool too. I did not want to put a big tail on the car though, I wanted to keep the sleeper look... So, we fabbed a custom intercooler to fit under a ducktail.
Tha car was run on the dyno with and without the intercooler. The numbers were very close in both configurations about 340RWHP without the intercooler and as much as 358.7 RWHP with the intercooler. The day the car was on the dyno it was 105 degrees, so I would imagine that on a cool day and with the car moving we should be making a bit more. The boost was run from 14 psi up to as high as 17 psi (.97-1.17 bar) with 91 octane as well as 100 octane fuel. NEVER a hint of detonation!!! Henry's Twin-Plug set-up is too cool. Based on the dyno numbers, I will run the car at 15psi (1.03 bar) and will enjoy right at 349 RWHP!!!!
I am also now running 17x8 & 9.5's with 235/275 Toyo RA-1's to keep her planted.
Bryan
'74 911-Not Stock...
typ911@gmail.com
Old 06-16-2006, 02:37 PM
Love the car.....
Its probably already posted but what trans are you running?
How stable is the rear when burning through the gears? I would think 2nd would be a blast on a wet skid pad.
Old 06-17-2006, 08:44 AM
Brando
quattrorunner's Avatar
It's amazing to see this car. I love it in every way. I have been putting a plan together to do something a little less radical than this. I am not ready to twin plug yet. Maybe I am. I will use the turbo 3.0 intake and fuel dist on a fresh rebuild o my 79sc. I love the old school carrera look, so It's cool to see someone build one like I wanted to see in my garage
Turbo powa!
1977 911s. it's cool
Old 06-22-2006, 11:53 PM
Send a message via AIM to Purkinjefibre
Intercooler
Hi Bryan, very nice intercooler installation, can i ask who made it? I have a ducktail too and would like to keep it rather than switching to a whale tail,
Brett
'79 SC-Silver Arrow
3.2ss-twinplug-EFI
Old 06-23-2006, 07:54 AM
