Dadofour's Avatar
Does this Flywheel match this Crankshaft?
I purchased a "Complete" engine on Pelican, and am not sure if the nine bolt flywheel matches the nine bolt crankshaft for this "1985 3.2 complete".
The Crankshaft has a roll pin and the flywheel does not. In addition, the flywheel is rusty. Is this normal/acceptable.
I appreciate the help as I validate that what I bought can be assembled.
Than
Than
My Track Schedule
1984 911 Viper Green Track Car - Parted out to fund
1993 BMW 325is Spec E36 Race Car
Old 10-06-2005, 03:12 PM
1972_911T's Avatar
That is completly the wrong flywheel for the 3.2 motor, looks to me like one off a 3.0 which is also a 9 bolt but as you say it does not have the roll pin. The purpose of the pin is to align the fly wheel on the 3.2 as it should have timing notches (like raised squares) on the outside of the flywheel which are used for timing etc. The 3.0 does not have these notches.
Old 10-06-2005, 03:29 PM
Dadofour's Avatar
I am running this 3.2 with the motronic ignition, so I assume this is the wrong flywheel.
Should I be asking for a flywheel that is "indexed" for motronic ignition?
Than
My Track Schedule
Old 10-06-2005, 03:35 PM
Irrationally exuberant
ChrisBennet's Avatar
If you look very closely, you'll see that the roll pin in superfluous. The bolt holes are such that the flywheel can only go on one way. I never noticed that until someone told me.
Pretty much any used flywheel is going to be rusty because you can't really oil them for storage.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 10-06-2005, 03:47 PM
Try not, Do or Do not
Henry Schmidt's Avatar
The 3.2 flywheel has speed and mark sensor attachment/ projections on it. This is not a 3.2 flywheel.
The dowel pin is there so that the timing/ ECU sensors will be indexed more accurately.
My guess is that you have a 3.3 turbo flywheel.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 10-06-2005, 06:45 PM
