20 dollar cam tool
I have had to tear down the 3.0 this last two weeks. My son noticed that the oil pressure was lower than normal. We changed the oil...ect no change. He drove the car one more day and it can home on a flat bed truck...We though we broke a valve spring. When we couldn't find that we pulled the engine...pulled all the valve covers, adjusted the valves and put the engine back in only to hear the same knocking sound....fast forward to this week, pull engine and start the tare down. I figured that is was a vavle we just couldn't see it...sorry no it wasn't...we spun a bearing. Number 5 cylinder has a bunch of little marks from something hitting the piston and the head. what i can't tell. which gets me to the reason for this post. the tools required to remove the two can nuts on an early car are just too much money to use two times. I f I had a shop it might be different. So I made my own tool and you can do it to. I'll see if the pictures I took will upload, if they don't here's what I did. In the early cars you need to have a 46mm wrench or crows foot tool to remove the nuts. both are expencive 89.00 and the wrench is over 100.00 bucks, so I found a 1 7/8 3/4 drive socket wrench at the hardware store just down the street. I took my dremmell tool and cut away a piece of the socket to allow me to incert an 18mm wrench to keep the cam from turning when you remove the nut. I spent about a hour working on the cutting of the slot. It needs to be big enough to get the nut to break...so it took a while. also the portion you leave should be as thick as the nut. You are basicly cutting a window in the socket. when I was done we put the socket on the nut and it fit good. If i was able to find a 46mmsocket it would have been perfect. the last step was to hook my impact gun to the socket, hold the wrench in the window on the flats of the cam and give it a try....WOW...two short blasts with the gun and the nut moved. perfect. then I used a socket wrench to get it the rest of the way. If you have time and a dremmel you can make one too...total price was 12.99 for the socket, 8.99 for the 3/4 to 1/2 adapter. soo much easyer than I expected. Sorry for the poor pics. really cheap camera. http://forums.pelicanparts.com/uploa...1128907207.jpg http://forums.pelicanparts.com/uploa...1128907283.jpg http://forums.pelicanparts.com/uploa...1128907320.jpghttp://forums.pelicanparts.com/uploa...1128907378.jpghttp://forums.pelicanparts.com/uploa...1128907465.jpg
Nice Craig!
Just so I get the picture correct, while rotating the socket, does the relatively short open end wrench rest against an immovable stop or do you hold onto it? It held, wouldn't it tend to rotate with the socket (as much as the chain allows anyway)?
Thanks, Sherwood |
Very cool. If you are able to get a breaker bar or pipe over the wrench and keep it stable, then it would eliminate any concern over the cam turning.
I did do a little research and found a company who could order me a single 46 mm crowsfoot for about $25. Just took a few emails to these tool companies on the web before one responded. |
The 18mm wrench rests against one of the studs on the chain cover or you can hold it. You then position the window of the wrench as close as possible to the wrench with respect to the direction you plan to turn the socket. If it doesn't line up right , just turn the engine over by hand until the cam flats line up better. With the air gun there wasn't much back torque. The problem that I found when wanting to remove the nut the regular way was the amount of force needed to break the nut...if I had used a crow foot I was afraid of the wrench poping off and me busting a hand or worse. This was so simple. The most time was spent looking for the socket., the cutting took about 45 minutes. If you use a 1 7/8 like I did...it is less than 2mm bigger, so the nut has more than enough bite. I'll post a couple more pictures soon.
Craig,
Thanks for the explanation. Sounds like a good idea. Sherwood |
Will a hex socket work or does it have to be star? Here's an option for a six sided socket:
http://store.yahoo.com/motostrano/46socducrear.htmlhttp://store.yahoo.com/motostrano/46socducrear.html But it costs $40 so it may not provide savings... There's always Harbor Freight. I bet they have a 46mm socket. |
I'm sure it might...looks very heavy duty and cost 3 times as much. Harbor freight only had a set of MM socket at around 59 dollars. Osh Hardware had some sockets but was out of the 17/8 size, their price was under 15 bucks. I got mine at a regular Do iT Best mom and pop hdwe store, ...they had two.
Web sight for stores is www.doitbest.com in search window insert this part number 309281. the on line price was 14.99. I think the 12 point would work better.
It makes sense that the 12 point should work better since it gives you the ability to make small adjustments. Sears also has a 12 pt 1 7/8 for $20.
The cam nut doesn't need any fine adjustments. It's fully tight or fully loose; that's the objective. A six-point socket provides more contact area with the nut, thus I suggest using this type, especially since the 1 7/8" socket isn't equivalent to a 46mm socket (it's slightly larger).
Sherwood |
$28 cam tool. Of course in 1978 when I bought it $28 was a lot of money for a socket.
http://forums.pelicanparts.com/uploa...1128979275.jpg |
LOL, good one Henry.
I've got one of those in my tool box but it cost alot more than $28. One of these days it will go up on e-bay, but as soon as it does I will prolly need it again. :( |
Do they make'm like that anymore???. As I mentioned in my post, if I did this for a living I would most likely buy a 46MM crow, I don't... and after seeing how easy removal was with an impact gun and my cam tool, I might not.
The reason you might want a 12 point is because it gives you more adjustments, one point left or right. |
Plus a thought: How can you use a torque wrench with your tool ? I know just impact it on;) |
The 12 point made moving the socket one point clockwise/ counter clockwise easy... a 6 point moves the whole socket 1/6th of the nut . Like I had said...if you can find a 46MM socket wrench , cut the window, use an 18MM wrench to hold the cam and use a breaker bar if you want, that's perfect...I couldn't find the 46MM. Before I used the impact I tried the breaker bar. I only used the impact to break the nut loose. two very short hits and the nut moved about 1/2 inch, enough to make removal with regular tools. The wrench is 3/4 drive so a torque wrench will fit like any other socket. I don't intend to impact it on to torque spec. But I do thank you for the idea. Just kidding.
Since I've been doing some cam measurements over the last few days, I happened to have this tool out on the bench. I've used it for several years instead of the factory tool. It fits better and is more open for better visual and physical access to the cam. It was made from a Snap-On crow-foot, size 1 13/16. Very close to 46 mm. I had a friend to weld in the piece that bridges the gap in the crows foot to keep it from spreading open on those really tight cam nuts. I have no idea what the Snap-on tool cost, that was a while back. But I wanted something to last. The part that protrudes to hold the 1/2 ratchet or breaker bar just clears the inside of the chain case.
http://forums.pelicanparts.com/uploa...1129343313.jpg Here is a photo of the tool in use. http://forums.pelicanparts.com/uploa...1129343370.jpg |
Jim,
Thats the way a real mechanic does things. Beautiful. But for removal, well an impacts the only way to go. Unless you have a tool like you made. |
THe hands best friend, everyone who has ever wrenched on a car knows how bad you can hurt your self if your wrench slips...nice tool. Did you make your chain holder too? The whole idea to posting things like this is to get you to think of things that would work without spending $$$.... I love tools, just not 89 dollar wrenches.
Craig,
The cam holder I can't lay claim to building. It is the Porsche factory tool. I thought I had a photo of this pair of tools in use taking off a stubborn cam nut, but I can't find it. For that pupose, these tools are supplemented by another set of home-made tools, a couple of pieces of 3/4" galvanized pipe. One piece fits over the end of the cam holder and reaches from there to the floor at about a 45 deg angle, off to the left. That is the cam holder. The other piece of pipe (about 3' long) fits over a 1/2" ratchet handle attached to the crow-foot. This makes pretty easy work of over-tight cam nuts. I have never had consistent good luck with using an impact wrench in this application. There's not much mass in the cam itself, so you need to counterhold the cam with some sort of tool. Of course you could use the breaker-bar-on-the-cam-holder like I use for this purpose, but then you don't really need the impact wrench if you have another piece of 3/4" pipe. ;^] |
Hey Jim,
My tool box has a few pieces of pipe in it too. |
I bought the same socket at the pawn shop. I used an air grinder to hollow out the 3/4" square drive to let the end of the cam stick through it. I then welded the socket to a piece of 1/4" X 2" stock about 3' long. This with an 18MM wrench allowed me to take get the cam nut loose by hand.
Love those pawn shop tools. David Duffield |
FWIW, I bent the metal handle of my cam holder tool trying to get the nut off with the crow foot wrench. They can be a beyatch to remove.
The modifications mentioned here are great improvements over the base tool. Sherwood |
I get that buying a factory tool to build one engine at home is excessive and I appreciate ali the cleaver means to avoid doing so. What I don't get is the suggestion that these tools function better than the factory tool. I'm been using the factory tool for over 30 years and can't remember having a problem with it. '
It is a fact that I'm getting old, maybe I have C.R.S. :) http://forums.pelicanparts.com/uploa...1129903309.jpg |
Hi Henry,
I had the factory tool in your photo, and was annoyed with the way it handled. It seemed to be rather bulky and cumbersome, and fit loosely, and often slipped off at unopportune moments. After having built and used the Snap-on modified crow-foot, I sold the factory tool, as it only sat in my tool box, unused. I really can't speak for the other DIY cam nut tools, but the Snap-on derived tool I described has been used to remove and install a lot of cam nuts, certainly a lot more than "building one engine at home". For me, it functioned better than the factory tool. Some of us are always looking for better ways to do things, included better engine sealants than the factory recommends. It's also a fact that I'm getting old, and I might have C.R.S. too, if I knew what it was. |
Let's try not to blame the tool for your lack of manual dexterity. :) Quote:
C.R.S = Can't Remember *****.:) |
Henry,
What was that C.R.S post for? I forgot. |
Hey Jim,
What do you think you spent on your wrench??? Its a very good idea and makes a safer open style wrench that a crow foot. When my engine is ready to reassemble I plan to use my socket set up. We'll see how well it works for that. |
Hi Craig,
The latest Snap-on price list I have (1999) says the crow-foot cost $25.50. The welding was free. |
Why use a crowfoot at all?
I used this $10 tool, that I bent in the right place: http://forums.pelicanparts.com/uploa...1111673791.jpg |
That bend job on the wrench is excellent. I love to see how people solve problems. I'd like to see more options of how to fabricate alternatives to expensive Porsche tools.
Thanks for sharing! |
Great Picture...$10 bucks. I looked for a wrench that big, couldn't find one. Im with Riskybusiness, What other tools /ideas have the readers came up. Please share.
Magnus,
Looks like something I would have done myself, if I'd thought of it.... What is the length of the wrench? I was wondering how much leverage it provides for loosening those really stubborn cam nuts. |
I have a chineese tool exactly like it. Just looking for my picture. If I find it I will post, but why, its the same.
The cam holder socket is another topic, it bent and slipped on my cam.... Worst piece of crap I have seen anyone call a tool.... |
Great ideas! But, how about putting things back together? Other than the crow's foot, how are you applying the correct torque?
I'd think the crow's foot or modified socket are the only way.
I have the factory tool also. Granted, I have poor hand eye coordination, but I find the factory tool a little clumsy as well.
I wonder if Henry's 30 yr old factory cam tool is a better fit than the "factory" (reproduction?) cam tools we get now? -Chris |
Clumsy yes, but the galvy pipe makes it work.
