injector question 3.2
can someone explain this blue cap? I got six of these rebuilt injectors and put them in, I didn't mess with the end sleeve at all, and I got no spray out of them. So I took them all back out. two of them left their blue sleeves in the bore for the injector. I put my old ones back in with the orange/yellow sleeve and sprayed, started fine. One by one I tested these new ones at the number one cyl. Four of them wouldn't spray at all. Of the two that left their blue sleeves in the runners, one of them I pushed the blue sleeve back on tight and it sprayed contstantly until pressure in the rail bled off. The other one I put a new yellow sleeve from one of the oring kits from pelican. It seemed to spray fine so I left it in, put it all back together and it stated fine and runs fine. I cant fugure it out. From the beginning I had all six in with rags underneath to catch the gas, but nothing came out. I ran the pump for a while before actually cranking it over, And I was getting good pressure at the test port.
I swear I'm missing something. I'd bet a paycheck these are good injectors, I just did something wrong. The bosch book didn't say much.
Old 10-13-2005, 04:45 PM
KobaltBlau's Avatar
the blue isn't just a protective cap from the injector rebuilder, is it? Sounds like one of them sprayed with the blue cap on, though...
Andy
Old 10-13-2005, 04:59 PM
Send a message via Yahoo to Lukesportsman
sometimes the needles get stuck from dried fuel. A little acetone should open them up. Hard to tell in the photo what the blue part actually is.
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT
Old 10-13-2005, 09:48 PM
