-   -   To Hone Or Not To Hone (http://forums.pelicanparts.com/911-engine-rebuilding-forum/248371-hone-not-hone.html)
1972_911T 10-28-2005 12:06 PM
Ok im just about ready to finnish my cylinders and heads, im using original nikasil cylinders and pistons with new rings, how do you know if you need to have the cylinders re honed my cylinders still bear good hone marks, should they be rehoned as matter of course or if the hone marks are still present is re honeing necessary.
One of my cylinders.
http://forums.pelicanparts.com/uploa...1130526312.jpg
Any advice appreciated.
sammyg2 10-28-2005 01:22 PM
On my nikasil cylinders, I just used some solvent and some good sharp scotch-brite to clean and skuff up the bores. Basically just cleaned most of the crap out of the metal pores. No hone.
I installed new rings, no smokey. The rings seated with no drama.
YMMV.
Have you measured them to see if they are round, in spec, and don not have a step or taper?
Henry Schmidt 10-28-2005 06:45 PM
CHECK THIS OUT
http://forums.pelicanparts.com/showthread.php?s=&threadid=163663&perpage=20&pagen umber=1
Jeff Alton 10-30-2005 10:08 PM
I have used the scotch brite method mentioned by henry in the thread he linked twice since I posted the original question. Both motors had the rings seat very well.
Cheers
alphie 11-01-2005 07:17 AM
To Jeff or anyone, what type of scotch brite do you use to hone the cylinders and where can it be bought?
Also, what solvent is recommended?
Thanks,
-Rob
Jeff Alton 11-01-2005 08:16 AM
I used the medium red grit one and a generic aresol degreaser. I also washed them thouroughly in soap and water to start.
Cheers
1972_911T 11-01-2005 08:22 AM
Is it possible to over do it with the scotch pads or are they not abrasive enough to make the cylinders too harsh?
Tom F2 11-01-2005 10:36 AM
Wow! What a great thread. Thank you, Henry.
Tom F2 11-01-2005 10:42 AM
euro911sc 11-01-2005 10:42 PM
If I could hijack this thread a little... On these two I can see some scratches or hone marks... not sure. Nothing like Steve's though! From reading the posts in the other thread I guess I'll just scotch them?? Hope for the best. Suggestions?
#1
http://forums.pelicanparts.com/uploa...1130912797.jpg
#3: Expected ring failuer here, but no evidence yet...
http://forums.pelicanparts.com/uploa...1130912955.jpg
On the other clys I can not see any hone/scratches at all. Car has 90k miles, but its an ROW so I'm not really sure.
-Michael
Henry Schmidt 11-04-2005 10:31 PM
More important is the evidence of valve to piston contact.
Check your valves carefully.
