LinkBack Thread Tools Rating: Thread Rating: 3 votes, 5.00 average.
Jeff Alton's Avatar
do I need to hone this?
Does this nicasil cylinder need to be honed to have rings seat?
Cross hatch is still clearly visible.
Thanks, Jeff
www.turn3autosport.com
Old 05-18-2004, 09:18 PM
Friend of Warren
I did. I used a flex hone on mine. About 3-4 passes on each cylinder. Now have about 1500 miles on the rebuild and so far using NO oil! Here is a picture of one of my cylinders during the tear down and you can see that it look identical to yours. My concern was that the cylinder wall was too slick looking and the rings wouldn't seat. Flex honing gave the walls a much duller look.
Kurt V
Old 05-19-2004, 06:27 AM
Jeff Alton's Avatar
Thanks, I think I will send them out to a place here that has diamond hones and see what they think.
Cheers, Jeff
Old 05-19-2004, 07:06 AM
nreed's Avatar
My 3.3's looked the same after 100K miles. I measured the clearances and they were only half way to the clearance tolerance. I am sending them to be honed just to be sure.
Norm '86 930
AEM Infinity 6 - Twin Plug 3.6L - DBW - JE Pistons/LN Eng. Cylinders - Pauter rods - GT3 Crank - GTX3584RS - ID1050x Injectors - Ported Intakes - Custom Intake Manifold, exhaust and intercooler - 993SS cams - ECUMASTER PMU-16DL
HRE Wheels 560R 8.5x18 ET25 (Front) 11x18 ET0 (Rear)
Old 05-19-2004, 07:12 AM
Friend of Warren
Why not just buy the flex hone for $50, chuck it up in a drill and do it yourself?
Kurt V
Old 05-19-2004, 07:47 AM
Jeff Alton's Avatar
good Question?!?
Old 05-19-2004, 07:53 AM
nreed's Avatar
Actually I have a grape hone but was kind of unsure whether to use it or not. If I use it, would I just pull it through a couple of times? I don't want to damage the cylinder walls.
Norm '86 930
Old 05-19-2004, 07:54 AM
Friend of Warren
Yes just lube the cylinder walls up with some 20w50 (actually and motor oil will work just fine) Use a drill with about a 500-700 rpm speed and move it up and down in the cylinder 3-4 times making sure you push about a third of the hone out past the bottom of the cylinder and up through the top of the cylinder to make sure you hone all of the cylinder. Not much danger of hurting the cylinder walls with the flex hone (what you call the grape hone) that is why Wayne and others recommend its use. It really doesn't "hone" the cylinder like the hones that use the 3 honing stones do. It just scuffs it up a bit.
Kurt V
Old 05-19-2004, 08:28 AM
nreed's Avatar
Kurt V...Thanks for the encouragement
Norm '86 930
Old 05-19-2004, 09:10 AM
Hi,
Could you post a picture of before/after honing ? for us novices could be interestig to see the difference. Maybe even the 'flex' hone.
Thanks,
Michael
Old 05-19-2004, 09:42 AM
Try not, Do or Do not
Henry Schmidt's Avatar
No No not a hone !!
It has been our experience that if you hone Nicasil cylinders the hone cuts into the Nicasil and because it is so hard that the new ridges are too abrasive on the rings. The rings will seat but they will not last as long as they would if the cylinders are prepped properly. We have had great results from Scotch Brite with soap and water. This breaks the glaze but doesn't cut the Nicasil. Don't forget to check for roundness. I've seen Porsche cylinders .004 out of round.
P.S. use only Goetze rings. Hastings in a pinch.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 05-19-2004, 01:25 PM
Slumlord
Porsche_monkey's Avatar
Why hone if the cylinder walls are not glazed?
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 05-21-2004, 05:00 AM
Air Medal or two
afterburn 549's Avatar
Sometimes you guys scare me!....I wont flame you, but I wish you had asked the Q. b4 you did it!!! So next time just dont
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 05-22-2004, 07:14 PM
Jeff Alton's Avatar
Afterburn, is your post directed at me? If it is, I am not sure I understand.
Jeff
Old 05-24-2004, 10:18 AM
Air Medal or two
It is directed to anyone that would break out a nasty hone on that Gourgous cyl!.......please don't
Old 05-24-2004, 05:14 PM
Jeff Alton's Avatar
Very well, thanks.
Jeff
Old 05-24-2004, 09:44 PM
Air Medal or two
The wall on that is SOoo thin.....you go thue to the aluminum in a hurry!
Old 05-24-2004, 09:52 PM
Unoffended by naked girls
dhoward's Avatar
Send a message via AIM to dhoward
NOT WITH A GRAPE HONE!!!
A grape hone is not hard enough to remove Nikasil, unless the cyl has been gouged and the coating is already flaking....
Or, just Scotch-Brite it as someone else mentioned.
Dan
1969 911T (sold)
2008 FXDL
www.labreaprecision.com
www.concealedcarrymidwest.com
Old 05-25-2004, 05:44 AM
Friend of Warren
I did ask on this board (engine rebuilding) prior to using the grape hone and the responses were that a grape hone (flex hone) is not a true hone and is not hard enough to cut through the nikasil, but is sufficient to remove the glaze. My concern with my cylinders were that even though I could see the factory hone marks, the cylinders were too smooth and the rings would never seat. I now have 2000 miles on my rebuild and burning no oil at all. Where do you get the information that using the grape hone would damage nikasil cylinders??????
Kurt V
Old 05-25-2004, 06:12 AM
Tags
nicasil
