1972_911T's Avatar
To Hone Or Not To Hone
Ok im just about ready to finnish my cylinders and heads, im using original nikasil cylinders and pistons with new rings, how do you know if you need to have the cylinders re honed my cylinders still bear good hone marks, should they be rehoned as matter of course or if the hone marks are still present is re honeing necessary.
One of my cylinders.
Any advice appreciated.
Old 10-28-2005, 12:06 PM
Unregistered
sammyg2's Avatar
On my nikasil cylinders, I just used some solvent and some good sharp scotch-brite to clean and skuff up the bores. Basically just cleaned most of the crap out of the metal pores. No hone.
I installed new rings, no smokey. The rings seated with no drama.
YMMV.
Have you measured them to see if they are round, in spec, and don not have a step or taper?
Old 10-28-2005, 01:22 PM
Try not, Do or Do not
Henry Schmidt's Avatar
CHECK THIS OUT
do I need to hone this?
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 10-28-2005, 06:45 PM
Jeff Alton's Avatar
I have used the scotch brite method mentioned by henry in the thread he linked twice since I posted the original question. Both motors had the rings seat very well.
Cheers
www.turn3autosport.com
Old 10-30-2005, 10:08 PM
To Jeff or anyone, what type of scotch brite do you use to hone the cylinders and where can it be bought?
Also, what solvent is recommended?
Thanks,
-Rob
'79 SC
Old 11-01-2005, 07:17 AM
Jeff Alton's Avatar
I used the medium red grit one and a generic aresol degreaser. I also washed them thouroughly in soap and water to start.
Cheers
Old 11-01-2005, 08:16 AM
1972_911T's Avatar
Is it possible to over do it with the scotch pads or are they not abrasive enough to make the cylinders too harsh?
Old 11-01-2005, 08:22 AM
Originally posted by Henry Schmidt
CHECK THIS OUT
Wow! What a great thread. Thank you, Henry.
Old 11-01-2005, 10:36 AM
CHECK THIS OUT
Old 11-01-2005, 10:42 AM
Less brakes, more gas!
euro911sc's Avatar
If I could hijack this thread a little... On these two I can see some scratches or hone marks... not sure. Nothing like Steve's though! From reading the posts in the other thread I guess I'll just scotch them?? Hope for the best. Suggestions?
#1
#3: Expected ring failuer here, but no evidence yet...
On the other clys I can not see any hone/scratches at all. Car has 90k miles, but its an ROW so I'm not really sure.
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 11-01-2005, 10:42 PM
More important is the evidence of valve to piston contact.
Check your valves carefully.
Henry Schmidt
Ph: 760-728-3062
Old 11-04-2005, 10:31 PM
