Wer bremst verliert
JohnJL's Avatar
Camshaft front-to-back play
I'm checking my valve-piston clearance with a dry assembly and have the right side camshaft in, thrust washer, 3 washers (per previous build) and the woodruff key installed. When I have the sprocket flange installed flush with the camshaft, the camshaft still has 2.1MM front-and back play. Is this normal?
thanks
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 10-31-2005, 12:38 AM
Wer bremst verliert
JohnJL's Avatar
Well I found once the bolt (this is an DR 20 on an 83 cam) was tightened, the play is gone.
Another question now...I'll do some searching but is there a way around the cam bar tool (p237?) tool?
It seems a but much a tool I'll only use few times.
Great post the other day on making your own early cam holder from a socket with a dremel...
Old 10-31-2005, 02:11 AM
Now in 993 land ...
aigel's Avatar
I have used this tool. I can't see an easy way to make it. Lots of torque on those pins. Borrow it for a sixpack seems most reasonable!
George
81 SC (sold)
Old 11-03-2005, 10:58 PM
Wer bremst verliert
JohnJL's Avatar
Wayne,
I always did, but now being in Australia, by the time it gets here and through customs it costs 2X the list price.
I've always been happy with and advocate buying from Pelican. My 993 wires, tune up parts, caps, filters, gaskets, and all the rebuild kits for my 911 engine have been top quality and I've received excellent support.
John
Old 11-04-2005, 06:52 PM
