Leakdown tester
I am finally getting ready to drop my engine and replace head studs/top end job. I have not done a leakdown test on it and want to. Question is that the super nice Snap-on tester retails for $299. I see inexpensive testers on eBay for $75. Now I usually prefer really good tools but has anybody used these less expensive leakdown setups? In this case I and a buddy might use the tool twice a year, not several times a week like a real shop. Is there an issue with accuracy of the inexpensive testers ? Or of course any local Pelicanites that want to let me borrow one....
Richard Lane
1978 911SC
1973 "Clean" RS clone
Old 11-03-2005, 11:01 AM
Jeff Alton's Avatar
The accuracy is related to the quallity of the guages. The basic hardware should all be pretty similar. I have used a cheaper one for years with out any problems. .... You could always get a cheap one and replace the guages if you were really concerned about them.
Cheers
www.turn3autosport.com
Old 11-03-2005, 11:20 AM
syncroid's Avatar
I have been using one of the less expensive ones for years and it works fine. (till I dropped it the other day) :O
This is it, or was it.
Dan
2002 996 C4 Cab w/ Jake Raby 4.0
2024 Tacoma TRD Offroad 4x4
2003 Range Rover HSE
Old 11-03-2005, 01:52 PM
Tavia Performance makes a good one and it is not too expensive:
http://www.tavia.com/cat8.html
Old 11-03-2005, 07:43 PM
Try not, Do or Do not
Henry Schmidt's Avatar
The two gauge types show differential pressures and tend to be more accurate.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 11-03-2005, 07:58 PM
Less brakes, more gas!
euro911sc's Avatar
I bought a used 2 gage Longacre one off ebay for less than $40. Worked fine after I resealed all the joints. I might swap the gages out at some point if I have nothing else to do.
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 11-03-2005, 09:19 PM
Thanks guys, I scored one on eBay this AM for $50, time will tell!
Richard Lane
1978 911SC
Old 11-04-2005, 04:48 AM
RiskyBusiness's Avatar
Leak down testers are not rocket science. I rolled my own using instructions found here. All the parts costs about $20. I got a regulator/gauge combo at Northern Tool
I upgraded it a bit by using an air hose with a swivel and a number of quick connects.
This is a motorcycle site but the same tool works for autos. I have created different ends for each motor I work on. I'm very pleased with it.
Richmond Virginia
1991 964 Targa
Old 11-04-2005, 06:04 AM
Richmond Virginia
1991 964 Targa
Old 11-04-2005, 06:20 AM
