Well, the saga continues. Today I had about 4 hours to work on it. I started by taking off the wing and some of the brackets that hold it to the transmission. This car is a short tailed version. I then removed some of the wiring harness to the back along with the vent tubing and the air jack. Following this the transmission cooler, rear stabilizer adjustment system and transmission linkage came off. This left the suspension system including the brake ducting, brakes, brake lines, shocks, rotors, axles and cv joints, uprights, upper suspension frames which had to be removed before finally the separation and removal of the transmission from the bell housing. I discovered that the right rear bearing will have to be replaced since it is getting notchy. As is the case with most of these massive tear downs other problems are also discovered (music playing...$$$$). Some of the spherical bearings on the lower a-arm will also need to be replaced so if anyone knows a good inexpensive source for metric bearings I would appreciate it if you could let me know. I also drained the oil tank, transmission and fuel cell. I picked up about 7 gallons of race fuel that has been sitting in there for more than 5 years which should be good enough to run the lawn mower and other 2 cycle power tools. I also managed to spill a couple of gallons down my arm and onto the floor. Atleast the floor is a little cleaner. A few more nights and I should have the motor out. I ordered a engine stand adapter ring from Pelican Parts and hopefully it should be here in time to mount up the engine. I hope it fits. Attached are some pictures of the progress. I would like to post more but it takes forever to upload them. Thanks all for your thoughts. I am learning things I never knew about this car and motor. Note the last picture of the transmission and the input shaft. For those of you who don't know, there is a spline to spline sleeve that slides off so you can remove a cover plate on the bell housing and do a clutch replacement without removing the transmission....something I wish I had on my 911 GT4 when I had a clutch failure and had to pull out the motor...twice (actually the flywheel bolts had backed out and were interferring with the pressure plate mechanism).
Old 11-08-2005, 09:15 PM
Warren Hall Student
Bobboloo's Avatar
Your goin great guns there.
This is such a great treat to be able to see the tear down of one of these cars.
Do you have any reference resources or are you just winging it on the disassembly?
P.S. I just noticed how impotent the list of chassis modifications in my signature look after viewing pictures of your car.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 11-10-2005, 12:08 AM
Today's progress includes the removal of the bell housing, starter, some of the support frame parts and oil tank and attached lines. The plumbing and wiring is a nightmare so I am going to label everything.
I found the Andial number. It appears to be #253. There are also some numbers taped to the intake manifold. Maybe one of you can tell me what they mean.
I got my engine stand adapter ring tonight. For those of you who have used it please bolster my confidence that only 2 bolts on the engine case are enough to support the weight of the engine!
Also, I don't know if you can make out the red material in the head cylinder seam but does anyone know if this is Loctite or some other sealant?
Old 11-10-2005, 12:17 AM
I am just winging it for the most part although I did take the car down this far about 8 or 9 years ago before. As the engine comes out I however will be in new territory. It really is not as difficult as it might look. You just need to be methodical and think twice/carefully wrench or force once. I remember the first time I took a look under the hood. My brother and I looked at each other and just said wow! I then just philosophically said "I guess if man made it man can take it apart" and we dug in. Towards the end of the disassembly I got a hold of a copy of the parts manual which helped some and talked to a few different people around the country for some tips here and there when we put it back together. I guess that makes me an expert now (LOL)......
Old 11-10-2005, 12:30 AM
Licensed User
Shuie's Avatar
Thanks very much for sharing pictures and for documenting what you are doing. This is a very rare oppurtunity for a lot of us to see one of these cars this close up.
Old 11-10-2005, 04:46 AM
KobaltBlau's Avatar
Agreed! thanks for taking the time to take and post the photos!
Andy
Old 11-10-2005, 10:12 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Just an uneducated guess: maybe these are some sort of calibration results for fuel/oil flows or pressures at different engine speeds.
Doing a google on SHIRAZI is scary....
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 11-10-2005, 11:27 AM
Doesn't want/need a 3.6L
Carrera3.5L's Avatar
[img]
What did I tell you about the water pumps kind of looking like turbochargers? Of course, these "turbos" are driven off the intake camshafts.
AN 253 may or may not be the Andial engine number (although it probably is). The engine number should be stamped next to the flywheel close to where the oil breather/thermostat is. Wow, Andial built 253+ 962 motors? Not exactly. I believe they started at 100 with the building of their first race motor, which could have been a 917, RSR, 935, etc.
"Master" refers to the left bank (cylinders 1-3) and "Slave" refers to the right bank (cylinders 4-6). The 4 digit numbers for fuel and oil that are typewritten on the paper get programmed into the car's ECU when the engine arrives from Andial for installation. I don't remember/know how the numbers are derived, but I will guess is that it is for regulators/sensors/etc. I will have to ask one of my 962C engine buddies if you really want to know.
"Shirazi" has me stumped. My initial guess is that may have been the engine builder's last name, but to the best of my knowledge (and I can tell you for sure between 1982-1998) Andial/PMNA has never employed anyone with the last name Shirazi. Since my friend Steve left PMNA in 1998, Eric Bloss is the only one still building these motors when required. The rest of the guys are building Cup car and GT3RSR motors and their variations.
Ralph
1988 Carrera w/ 3.5L Twin-Plug
2008 Cayman S (coming soon)
Old 11-10-2005, 04:45 PM
KobaltBlau's Avatar
could it be the customer?
Andy
Old 11-10-2005, 05:37 PM
Ralph
I do believe that Shirazi was the name of the guy who bought the car from Schupann after the car ran at Daytona. I believe he had the motor redone at some point before I bought the car and I was told it had 4 hours on it and that those 4 hours were put on it by some Frenchmen at the Moroso track who were interested in buying it. Shirazi owned I believe the Auto Toy Store in Florida which I understand went out of business.
If you ever do hear from your 962 friends about what those numbers mean let me know. It is always fun to hear more history about the car.
253 is stamped on the location you decribed as well.
I had a few hours to work on the car today and got most of the final support frame off of the car along with some of the plumbing and exhaust headers. Oil was found in the forward pipes, something that has always bothered me. In the past when the car has been sitting for a few hours and you start it up it blows out the exhaust and smokes. The first time I started it I blew oil all over the driveway. At one of the first PCA race events I went to, the tech guys were convinced that the car had a problem and were afraid that I was going to spread oil all over the track. The almost didn't let me run until I could show them how it cleared up after a few seconds and that it is typical for this car....at least that's what I have been told too! I will be curious to see if there is an explaination when I take the motor apart aside from the fact that the oil tank is higher than the cylinders.
A few more pictures.....
The one painfull experience was the removal of the out exhaust header bolts and my solution. You can't get a socket on them and an open end wrench hits the flanges and is too long, even if it is a stubby. Maybe they make a special wrench for this...I cut a cheap closed end 12 mm wrench I had laying around and had barely enough leverage to loosen the nut.
I now only have 4 oil lines to remove, the inercooler/intake manifold connection tubing and a few wires and 4 nuts and the engine will come out. I thought I would get it out tonight but have a helicopter safety meeting to go to.
Old 11-10-2005, 06:34 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Notice all the Wiggins clamps on this beautiful engine. I thought only F1 and the space shuttle used that stuff.
BTW: we have a pretty good supply of Wiggens hardware in stock. Call if we can help.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 11-10-2005, 07:19 PM
Wiggins clamps are the state of the art clamps for fluid control/movement.
Two flanges with o-rings, one sleave and a hinged clamp. Sure beats the h*ll out of hose clamps.
Henry Schmidt
Ph: 760-728-3062
Old 11-10-2005, 07:48 PM
MBruns for President
JeremyD's Avatar
Don't know if this helps, but Florida Division of Corporations reports:
EXOTIC AUTO TOY STORE INC.
PRINCIPAL ADDRESS
2206 HOLLYWOOD BLVD.
HOLLYWOOD FL 33020
Corp Entitity - ADMIN DISSOLUTION
SHIRAZIPOUR, MORRIS
Old 11-10-2005, 08:38 PM
ischmitz's Avatar
PRINCIPAL ADDRESS
HOLLYWOOD FL 33020
SHIRAZIPOUR, MORRIS
I wonder if that is the same Morris Shirazi that comes up in connection with all the IMSA races in the 90's. He was racing a Spiece Chevy. The results do mention an Auto Toy Store. So it must be him....
Old 11-10-2005, 09:42 PM
It is the same guy.
Old 11-10-2005, 10:09 PM
Do you have the o-rings for the Wiggens clamps? I will probably replace all of mine. I don't remember if they are special or not.
Old 11-10-2005, 10:13 PM
KobaltBlau's Avatar
wiggins clamps on the water system make me think porsche wasn't so comfortable with water! or maybe andial are the ones who started using those clamps.
Andy
Old 11-10-2005, 10:49 PM
Wiggins clamps are another wonder of the world. Only weakness of these are the rather soft sealing sleeves. They wear fast from vibration and chafing. Stainless sleeves are a great fix and a preventive measure. Also a good idea to safety wire them upon assy and race prep.
Love reading and following your progress! keep the pics flowing
Old 11-10-2005, 11:18 PM
Super Moderator
cstreit's Avatar
Jesus what I wouldn't give to get my wrenches on your car and help out. In contrast to usual I'D bring the beer for the chance to help....
Nice work so far and I certainly appreciate your taking the time to document this.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 11-11-2005, 05:01 AM
just wanted to subscribe to this thread
are these the clamps you are talking about (and the o-ring sizes)
Old 11-11-2005, 09:10 AM
