Eye of the Toiger
RS Cylinders 2nd Hand
I want to purchase these cylinders they are RS cylinders/Pistons and have only done 50K miles.
They need a polish, what to you guys reckon for 2nd handers any good?
http://www.aircooled.com.au 1973 911 RSR clone powered by 77 3.0 turbo |
Author of "101 Projects"
RS Cylinders = same as any other 2.7 CIS cylinders = nothing really too special.
The pistons are low compression 8.5:1 - I typically don't recommend rebuilding to RS specs, but instead bumping the compression. -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Eye of the Toiger
So on my stock CIS 2.7 motor I can put in s cams and MFI?
http://www.aircooled.com.au 1973 911 RSR clone powered by 77 3.0 turbo Last edited by matty74; 11-04-2005 at 02:34 PM.. |
no you cannot use s cams with your CIS pistons. You can use JE pistons at 9.5:1 or so with single plug, but will need good nikasil cylinders. note that alusil cylinders can be replated. That RS piston looks kind of scored but it might just be the flash.
Andy Last edited by KobaltBlau; 11-04-2005 at 03:26 PM.. |
Gon fix it with me hammer
wile the regular 2.7's could be Alusils or Nikasils?
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
Yes, Stijn
Andy |
I thought the pistons looked a little scored myself. Just go with some JEs and bump up the compression per Wayne's recommendation.
Charles Navarro President, LN Engineering and Bilt Racing Service http://www.LNengineering.com Home of Nickies, IMS Retrofit, and IMS Solution |
Matty74,
Almost finish with a rebuild on the same type engine with RS pistons. If you follow Wayne's book you will probably have trouble with the valve/piston clearance check. That's with stock CIS. If you fail that check you have to pull the pistons back off and get them shaved.
'77 911S w/'81 3.0/MegaSquirt/MSD '81 911SC stock |
Also check the condition of the cylinders. At 50k, they should still have the cross-hatch pattern on them. If the pistons look okay (skirt wear pattern is suspect), compare specs with measurements for piston ring side clearance and piston OD (and thus piston-to-cylinder clearance). I've seen new sets for $1500-$2500. If all is okay, add in the cost of a new ring set, then price these accordingly.
Some say the life span of JEs is not on par with the factory Mahle's. Same with piston clearance. The more clearance, the more noise, especially during warmup. More clearance at normal operating temps. creates more ring wear as well. Don't polish the pistons (only the crown, if desired). MHO, Sherwood |
"You can use JE pistons at 9.5:1 or so with single plug, "
as a data point - i used 10.5:1 JE's and had no det'n problems with our (ie. aussie) premium fuel (nb: GE80 cams). however, the engine runs much much better (particularly under 4000 rpm) now we've converted it to twin plug.
Cheers, Ryan 1969 911E (historic racer) 911ST replica (tarmac rally) |
Try not, Do or Do not
If the pistons are still in spec, you can use the scratches to hold dry film lubricant.
The rougher the surface the better it (dfl) holds. Dry film will not bring back missing material but if they're in spec. I'd use them. It is hard to diagnose anything from 5000 miles away so check for cracks and measure, measure, measure. All Mahle piston have a size group designation so if they show a little ware you could put the piston in a cylinder that is one size group smaller. I.E.: put a #2 piston in a # 1 cylinder. Of course new is better and more money.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Doesn't want/need a 3.6L
Mahle Motorsport also makes a 90mm RS piston/cylinder set with a 9.5:1 CR instead of the standard 8.5:1. These would work fine should you ever decide to install MFI and "S" cams.
Unfortunately, you can't buy the pistons individually and reuse your cylinders, you would have to spring for the whole piston/cylinder set. Not cheap, but at least you would have Mahle quality. Ralph |
