Incomplete Reinz gasket sets?
The Reinz gasket set that I purchased recently was missing the cylinder base gaskets. The set was sealed when I received it, and had the laser printed Reinz sticker on it, too. Has anyone else had a similar experience recently?
Old 11-09-2005, 10:38 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Gasket set are quite often missing gaskets.
If you need just the base gaskets in a hurry, we stock them and they will fit in a next day envelope.
Cheers
BTW: we also stock .50mm.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 11-09-2005, 11:48 AM
