supchg911's Avatar
Question PSI to bar conversion
Can someone tell me what 7 PSI might convert to in bar? My guage is not metric but most people state their numbers in bar.
Thanks!
Old 11-11-2005, 04:05 PM
walt's Avatar
14.7 psi per bar therefore, 7 bar = 103 psi
Walt
82SC 3.0
81SC 3.6
Old 11-11-2005, 04:16 PM
supchg911's Avatar
Thanks for the lesson Walt!
Old 11-11-2005, 04:25 PM
Try not, Do or Do not
Henry Schmidt's Avatar
7 psi equals .476Bar
10 psi equals .68 Bar
20 psi equals 1.36 Bar
40 psi equals 2.77 Bar
60 psi equals 4.08 Bar
80 psi equals 5.44 bar
5 bar equals 72.52 psi
4 bar equals 58.01 psi
3 bar equals 43.51 psi
2 bar equals 29.01 psi
1 bar equals 14.5 psi
cheers
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 11-11-2005, 04:28 PM
supchg911's Avatar
Is there a way to determine the effective compression ratio, considering a 3.2 starts with 9:5 C/R and is supercharged with a maximum of 7 PSI (about .5 bar I've learned!) ?
Old 11-11-2005, 04:35 PM
3.2 liter
95 bore
74.4 stroke
.040 deck
34 cc dome volume
89 cc chamber volume
8.49 static compression
7 psi boost
14.01 final compression
Henry Schmidt
Ph: 760-728-3062
Old 11-11-2005, 04:48 PM
supchg911's Avatar
Wow! That explains the broken ring lands. Is there a formula that I could use to determine the best C/R for the new pistons?
Old 11-11-2005, 04:51 PM
9dreizig's Avatar
Send a message via AIM to 9dreizig
Henry, can you show your math?? ( seriously - but didn't want to sound like I was your math instructor) thanks
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 11-12-2005, 06:30 AM
David's Avatar
Old 11-12-2005, 08:41 AM
9drezig,
I'm not Henry, but using Bruce Andersons formula to calculate compression ratio, I'll show how it works.
The key numbers are V1=cylinder displacement in cc's. in this case 527.36cc's. V2=deck height displacement, 7.09cc's at .040" DH. V3=the head chamber volume, 89cc's. The last key number is the V4=piston dome volume, 34cc's.
Now with these numbers we calculate the volume of everything with the piston at BDC. Add V1+V2+V3 and subtract V4=589.45cc's.
Next we run the piston to TDC and we add V2+V3-V4=62.09cc's.
Compression ratio equals 589.45 divided by 62.09=9.49:1 compression ratio.
With the compression ratio figured out, we just need to know what 7PSI of boost does to the compression ratio. Henry already showed us 7PSI=.476BAR. So we multiply 9.49 time 1.476=14.01, the boosted compression ratio.
Try it yourself. I made a spreadsheet for compression ratio's. It really helped me understand the effect of changing any one value.
DOUG
'76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's.
'85 911 Carrera, stock, just painted, Orient Red
Old 11-12-2005, 10:03 PM
9dreizig's Avatar
Great thanks for the input ( life is so much easier if you understand the math involved LOL)
"Todd"
Old 11-13-2005, 12:11 PM
2.7racer nailed the math. Sorry I didn't respond sooner but things get busy around here sometime.
Henry Schmidt
Ph: 760-728-3062
Old 11-13-2005, 02:33 PM
1bar = approx 14.5psi not 14.7psi
Old 11-14-2005, 08:26 AM
Unregistered
sammyg2's Avatar
1 bar = 14.508 psig
Yeah I know, but I crack myself up at least.
Old 11-14-2005, 10:55 AM
supchg911's Avatar
and if it is approximate, then 14.5 psi = 14.7 psi!
Old 11-14-2005, 11:17 AM
download josh madison's converter for everything you can think of. free download and keep it on your desktop. http://www.joshmadison.com/software/convert/
206 637 4071
Old 11-15-2005, 12:17 PM
9dreizig's Avatar
Speaking of converting.. I learned something today here in Germany.. The germans refer to gas economy as say 8 liters,, which means that's the fuel required to go 100Km... kinda simple even though it's inverse notation liters/Km...
"Todd"
Old 11-15-2005, 01:00 PM
You can also just type "7 psi in bar" into Google search box and it will return...
7 pounds per square inch = 0.482633011 bar
Don't know if it makes GOOG worth $300 a share, but its sorta cool.
-Bernie
Old 11-15-2005, 04:02 PM
No 14.5 psi = 14.5 psi
Old 11-16-2005, 11:55 AM
