What tools do I need?
I am planning to try to fix an oil leak coming from the chain housing and the interface of the towers and the heads. What tools do I need? Should I do anything else while the engines out?
don ___________________________________________ 1963 356B Super 1969 911S 1981 911 SC |
If I understand the leaks you propose to repair you will need quite a few tools. Dial guages and holders, straight edge and holder, cam nut wrenches, torque wrench and hex bits, etc. Do you have Wayne's engine rebuilding book?
Yes I do. But I thought I could skip some of the rec'd tools from the book.
You can improvice the cam holder and cam nut wrench (if you have the early style cam nut 46mm), do a search.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Is there anyone out there who could lend the rebuilding tools?
