3.0 Valve guides
I'd like to hear opinions on valve guides and seals for a normally aspirated 3.0 street motor. I've come across several alternatives.
Thanks,
Randy
"not an expert, but I play one on message boards"
Old 12-09-2005, 12:28 PM
abit off center
cgarr's Avatar
alternatives to valve guides? do tell
______________________
Craig
G2Performance
Old 12-09-2005, 12:39 PM
Ah yes....there's one in every crowd, but usually it's me.
OK, to be more precise...viton vs teflon seals...which bronze alloy guides?
Old 12-09-2005, 12:45 PM
abit off center
cgarr's Avatar
I am using the phos/bronze guides, seems like thats what everyone is using, the ones with the shoulder on them, makes the install too easy, the seals are what I get in the top end gasket kit which should be the black ones, not the white which I think are the teflon..
Craig
G2Performance
Old 12-09-2005, 03:30 PM
Air Medal or two
afterburn 549's Avatar
If they are like most you have to turn them dwn to size to fit the hole
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 12-09-2005, 06:58 PM
