3.0 Valve guides
I'd like to hear opinions on valve guides and seals for a normally aspirated 3.0 street motor. I've come across several alternatives.
Thanks, Randy
"not an expert, but I play one on message boards" |
abit off center
alternatives to valve guides? do tell
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
![]() OK, to be more precise...viton vs teflon seals...which bronze alloy guides?
"not an expert, but I play one on message boards" Last edited by goose2; 12-09-2005 at 11:57 AM.. |
abit off center
I am using the phos/bronze guides, seems like thats what everyone is using, the ones with the shoulder on them, makes the install too easy, the seals are what I get in the top end gasket kit which should be the black ones, not the white which I think are the teflon..
Air Medal or two
If they are like most you have to turn them dwn to size to fit the hole
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
Thread Tools | |
Rate This Thread | |
