You talkin' to me?
chancecasey's Avatar
how do i get heads/cam off oil tubes???
Sorry for the dumb question, but i'm removing the cam housing and heads as a single unit, but the dang oil return tubes are holding on like crazy so I can't slide the heads off.
Does everyone just crush and remove these even when rebuilding, or is there a trick / worth it to saving them? Could I torch them to melt/loosen the o-rings?
(964 3.6L)
Thanks!!!
-Chance
'90 C2 Cab - Temporarily out of service
Old 12-11-2005, 02:20 PM
Just use leverage to force them off..
Do not hit them with anything!
Kind regards
Old 12-11-2005, 03:19 PM
Jeff Alton's Avatar
Gently tapping on the cam housing with a soft rubber face mallett will work also. Work around the perimeter....
Cheers
www.turn3autosport.com
Old 12-11-2005, 04:14 PM
mppickett's Avatar
Set of 4 new ones are available for well under $50 from our sponsor. I crushed mine with a pair of pliers and wiggled them loose.
Old 12-11-2005, 06:01 PM
You talkin' to me?
I was able to gently pry them off while someone else pulled on them with their hands. Thanks a lot for all the suggestions! I'm also happy to report that I can still see all the cross-hatching in the cylinders (yay).
-Chance
Old 12-11-2005, 09:24 PM
