Eye of the Toiger
2.7l Mag case ALLOY replacement
Doing my rebuild on my 2.7l, I want to go to an Alloy case?
what are my options can I use a 3.0l case?
http://www.aircooled.com.au 1973 911 RSR clone powered by 77 3.0 turbo |
Either the early 2.0 sand-cast alu case or the very rare 2.7 Silumin case.
Practically speaking. the 2.0 Al case is the only real-world option.
I've only see one 7R Aluminum case in the past 33+ years.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Matt,
What's the problem with your existing case? Good Alum cases are getting harder to find as time passes. To make them work for a 2.7 requires a lot of work. Why wouldn't you just perform whatever work is necessary on your Mag case? Mark.
914/6 GT (Repro) Tarmac Rally car 928 S4 - 1989 911SC - 1980 944 TURBO - 1986 944 S2 - 1990 |
up-fixing der car(ma)
I agree that the 2.7 case will be probably less costly and better (lighter, more original, etc.) in the long run....what are you building? Adding case-savers to it will work well for almost any normally-aspirated 2.5-2.9 engine. If you are going to build a small-displacement turbo car or something of that nature (12.5:1 C/R?), that is probably when you should start looking for an early alu case.
Scott Kinder kindersport @ gmail.com |
Eye of the Toiger
No problem with existing I just was'nt sure the mag case last
For a full up race motor the Mag cases are weak. If you're car is primarily for the street and you keep to the 7200 RPM limit the case will last for many years if it has been prepared properly.
-Andy
72 Carrera RS replica, Spec 911 racer |
matt
another thing to keep in mind is that non-original case material will disqualify the car from a bunch of motorsport events in australia (eg. targa tas). something to keep in mind if you ever decide to sell the car as you may lose potential buyers and/or lessen value.
Cheers, Ryan 1969 911E (historic racer) 911ST replica (tarmac rally) |
Eye of the Toiger
Yeak you guys hve made my mind up, I'll stick with mag case
He hasn/t stated that he is doing motosport so if it is just a daily driver then I would go the path of capacity increase.
Michael |
Michael,
This is sort of a continuation of other threads Matt has posted recently where he has stated his preference for the 'Zing' of a 2.7 over the 'Grunt' of a larger engine...
