2.5 MFI Engine - Holiday Project
Here is a sneak peak at what I'll "hopefully" be doing between Christmas and New Years...
Short Stroke 2.5 MFI - Building it to be a fun street motor. - 77 7R Case - 66mm Counter-Balanced Crank - 2.0S Nitrated Rods - 3.0 Aluminum Oil Pump - Mod-Solex cams (camgrinder special - profiles between E and S cams) - Carrera Chain Tensioners - 90mm Mahle Nikasil Cylinders - JE Pistons 10.5:1 "RSR Style" (hopefully about 9.5:1 with the 66mm crank) - RS Spec Heads - Complete Stock 2.2S MFI setup (well one modification to the pump) - Single Plug 2.4 distributor All the machine work being done by Henry @ Supertec. I'll post some pictures soon..... Merry Christmas |
Try not, Do or Do not
Hi John
70.4 mm stroke 90 mm bore 1.0 mm deck 69 cc chamber 28.2 cc dome equals 10.5 to 1 comp ratio change only the stroke. 66 mm 90 mm 1.0 deck 69 cc heads 28.2 cc dome equals 9.9 to 1 comp ratio MERRY CHRISTMAS TO YOU AND YOURS
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Hey Henry....
I think when we spoke you suggested going to a deck height of about 1.25 which would bring it down closer to 9.5:1. That was the plan. I'm also thinking that JE's 10.5:1 estimate assumes a perfect world and that I wouldn't actually get that.
1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI |
When we built my 2.5L we had custom J&E's made because their off the shelf pistons do not always match the CC of your head. We CC'd the heads, and then told J&E what we wanted so we were sure of the compression.
Chad Plavan 911ST Race Car/2.5L SS Race Motor #02 1972 911T- Numbers matching- Restoring to stock 2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold) 2016 Elan NP01 Prototype racecar- Chassis #20, #02 Last edited by Plavan; 12-24-2005 at 09:08 PM.. |
All 90 mm JE pistons are custom made. At this time JE does not offer a shelf 90 mm.
As stated in my calculations, all necessary specs to produce the proper pistons are listed. That is all except valve size. At this time we are putting larger valves in 2.2-2.7 heads. Because I know what size valve John is running there was no reason to list valve size.
I meant when you order them from EBS Racing "Off the Shelf"
Chad Plavan 911ST Race Car/2.5L SS Race Motor #02 1972 911T- Numbers matching- Restoring to stock 2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold) 2016 Elan NP01 Prototype racecar- Chassis #20, #02 |
Stressed Member
John-
What will the port size be? -Scott
'70 911E short stroke 2.5 MFI. Sold ![]() ![]() ![]() '56 Cliff May Prefab |
I'm going with 36/36 and a stock 2.2S MFI setup. I didn't make as much progress as I had hoped but I'll post some pictures soon.
Stressed Member
John-
It sounds very much like the motor I'll be putting together in the next few months. I'll be using my '70E cams and E pump, and standard sized valves. Otherwise, identical. Why is Henry increasing the size of the valves with 36mm ports? I'll be very anxious to hear how it runs. My car won't be on the road until August. -Scott
He isn't... I'm using stock valves. My heads are essentially 2.7RS spec MFI heads. I think he was just saying that he now offers larger valves for the early 2.2/2.4/2.7 heads. I'm hoping to get this done in the next month or so....
Stressed Member
That's what I thought. Please keep us posted!
I didn't make as much progress as I would have liked to but here are a few pictures:
My "Assistant" installing the bearings I'm hoping to get time this weekend to make the necessary measurements to calculate the CR.. More to come
3 restos WIP = psycho
Nice pistons; what do you expect the CR to calculate to?
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
As you can see from Henry's calculation, the theoretical CR will be about 9.9:1 with the 66mm crank using a 1mm deck. I'm hoping to get it down to about 9.5:1 without going above a 1.25mm deck. I'm going to CC everything this weekend and calculate the expected CR and I'll let you know.
Ah, I missed that part of Henry's post. Why are you trying to back it off? If you are using 2.2 - 2.4 heads, they should be just fine at 9.9:1 even with single plugs.
What kind of horsies will something like this make?
JA
John - '70/73 RS Spec Coupe (Sold) - '04 GT3 (Sold) |
I just want to get the CR down to a reasonable level to avoid detonation. We have some weak gas here in California.
![]() I'm not sure what the HP will be (maybe 200).. Henry can probably help with this.
1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI Last edited by jbell959; 01-06-2006 at 09:13 PM.. |
Here is the dyno sheet from my 2.5L short stroke with 10.5:1.
More info on this thread: Dyno Day Pics
Those are great dyno numbers... What type of gas are you running? Did you measure the CR to see if you got was JE quoted? Very nice motor.
Thanks. I was also impressed by the work of Aase Motors.
This is my race car so I use 110 octane. Allan at Aase CC'd my heads and gave a custom order to J&E for a true 10.5:1 compression. Not the "off the shelf" pistons you can buy from EBS or others. I'm in the process of building a back up Long Stroke 2.5L at Aase's Shop. I want to have one of each
