adomakin's Avatar
how does this dial gauge and stand look?
saw this on ebay..... would it be adequate for my engine build?
Andy
1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Old 12-31-2005, 03:32 AM
Autobahn Garage
How long it the travel on the indicator? you need at least 1 inch. Harbor Freight has a set up like that for under $25.00
T Tanner
76, 911s w/ Webers
76, 914/4
57, Speedster
Old 12-31-2005, 05:23 AM
David's Avatar
The Z block works much better than a stand for holding the indicator. There's not a good area to mount a magnetic base. We calibrate all our indicators at the machine shop where I work and there's really no difference in accuracy between a cheap and high dollar indicator as long as they're both working. I suggest buying the Z block and a cheap NEW dial indicator.
Old 12-31-2005, 09:41 AM
al lkosmal's Avatar
For adjusting valves or cams, you can use the clamps that mount the extension arm to the base post to clamp to valve cover studs, or other studs close by, and adjust the extension arm to get to the right position. It's a little fussy, but it works. The valve adjustment will be much easier with the Z-Block. These measurement are pretty small. .004" (.1mm) for the valves and about that for the cam overlap, if my memory serves me, so make sure that your dial indicator resolution (increments of measure) is condusive to making measurements this small while still allowing a 1" or so total travel to accomodate the overall travel during cam timing. A indicator that measures in 1/100ths (.01mm) of a millimeter is good. Measuring in thousands (.001") of an inch works ok too.
RGruppe #669
http://www.x-faktory.com/
Old 12-31-2005, 10:11 AM
Irrationally exuberant
ChrisBennet's Avatar
Unless you are building a motor with a high lift cam, the standard dial indicators with 1/2" travel are sufficient.
Buy or borrow the "Z" block. The magnetic dial indicator base sucks for use on a motor made out of aluminum.
Given the dimensions, you could probably make your own Z-block out of wood in a pinch.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
I typically use a mag base indicator holder much like the one pictured, but as mentioned above, not a whole lot of steel to attach it to. So I took a piece of 1/4" plate steel and drilled a few holes in it. I slide the plate over a nearby stud and bolt it down.
Old 12-31-2005, 10:32 AM
adomakin's Avatar
hmm. getting hold of the z block over here is tricky. buying from pelican means $40 plus $29 shipping plus 20% import duty !! (ba$tards) has anyone got some rough dimensions so i could knock one up from wood? (chris?!)
Andy
Old 12-31-2005, 10:37 AM
David's Avatar
I'd suggest aluminum so it's rigid. I made mine, I'll see if I made a drawing.
Old 12-31-2005, 11:17 AM
adomakin's Avatar
thanks david
Andy
Old 12-31-2005, 11:47 AM
89turbocabmike's Avatar
I've used both but not all dial gauges will work with the z-block. I had to purchase another dial indicator with enough reach to extend through the z-block and hit the retainer.
rcwaldo's suggestion would work just fine since the engine is out.
Old 12-31-2005, 12:43 PM
David's Avatar
Here's a drawing I made of my block:
Old 12-31-2005, 04:12 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
even my chepo dial indicator has a scew-on tip. You can get extensions in pretty much any lenght for them to make it work with the z-block.
ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 12-31-2005, 06:24 PM
adomakin's Avatar
thanks for the plans david! and ill bear your comment in mind mike
hapy new year!
Andy
Old 01-01-2006, 04:26 AM
1972_911T's Avatar
Andy where in the uk are you I would be happy to loan you my Z-block, I have just finnished my 3.2 rebuild and know what a pain it is spending loads of cash on tools you hope you wont be needing again in a long time.
Old 01-01-2006, 11:22 AM
adomakin's Avatar
Hi Steve, i'm in essex. id be happy to 'rent' it off you!
how about you send it to me with your return address and i send it back to you with a drink as a thankyou?
Andy
Old 01-01-2006, 02:45 PM
