Engine savers for Mechanical tensioners
77 911s. Thoughts on these vs upgrade to hydraulic.
PK
Old 12-29-2005, 11:05 AM
Mechanical bad, hydraulic good.
-Andy
Old 12-29-2005, 12:08 PM
David's Avatar
I'll second that
Old 12-31-2005, 09:43 AM
al lkosmal's Avatar
I'd use the mechanical tensioners w/savers. The hydraulic versions have been known to fail, as well.
P.S. If you do a search on this topic you'll get all the opinions you wanted and more. it's been beaten to death.
RGruppe #669
http://www.x-faktory.com/
Old 12-31-2005, 09:50 AM
Ok,
I didn't understand the original post. I thought you were talking about pure mechanical tensioners which some people use on race engines. They just have a fixed adjustment and no plunger to take shock loads. The early tensioners I wouldn't call mechanical just early. Early tensioners can work ok if you update the idler arms and use the savers. I'd overhaul or exchange for rebuilt and add the later (1980+) idler arms before I'd be happy with them.
-Andy
Old 12-31-2005, 10:52 AM
