Ken911's Avatar
how to install pistons correctly
I am at the point of putting my pistons back in. I want to make sure they are not upside down. wayns book tells you to look at the domes for the valve notches. But this motor is a 3.3 turbo with flat topped pistons. the carb cleaner i soaked thenm in removed the makrkings i placed on them when i removed them. wayne can you help?
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 01-06-2006, 01:09 PM
Irrationally exuberant
ChrisBennet's Avatar
Look for an "E" on the top of the piston. This should go near the Intake. See this thread:
Which Way is UP ???
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 01-06-2006, 03:30 PM
Ken911's Avatar
sorry no E on the piston tops. there is a + stamped on the piston dome but i think that actually goes down.
2019 Silverado 6.2L
Old 01-07-2006, 05:47 PM
Ken911's Avatar
oh and the top is completely flat no notches or anything, checked the thread that you mentioned it looks like none of the ones pictured.
2019 Silverado 6.2L
Try not, Do or Do not
Henry Schmidt's Avatar
On a flat top piston that does not have an off set wrist pin the piston can be installed either way.
If it has an off set wrist pin there should be a marking on the dome that looks like a crank shaft with a flywheel installed.
The illustration shows the correct installation.
If there's no marking you can check the pin for off set by using a caliper to check the pin location.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 01-07-2006, 06:23 PM
Ken911's Avatar
which illustration?
2019 Silverado 6.2L
Old 01-07-2006, 06:50 PM
Ken911's Avatar
ok i got it figured out thanks!!!!!oh one more thing while were talking hor did you get your parts so shiney i noticed in several pics posted of engines you assembled looked really nice, you had commented that you put the parts in the dishwasher, well i did that they came out really clean but not any more shiney.
2019 Silverado 6.2L
Old 01-07-2006, 06:56 PM
Just hard work.
Henry Schmidt
Ph: 760-728-3062
Old 01-08-2006, 08:47 PM
Ken911's Avatar
AND? ok so did you hot tank the parts first then use a flapper wheel and a die grinder? bead blast every thing?
2019 Silverado 6.2L
Old 01-09-2006, 01:55 PM
