993 Engine Teardown pictures...
I have been posting to Rennlist some pictures of my 993 teardown. Its lots of work to repost so I thought I would post the threads for those who are interested. Its my first 911 rebuild so be kind... ;-)
DIY Rebuild Part I DIY Engine Rebuild II DIY Engine Rebuild III Cheers, Mike
Mike 97 993TT Arena Red - "Scarlett" |
Irrationally exuberant
Good post!
I see that you are estimating $800 to clean and micropolish the crank. Unless you are actually have the plugs removed to clean the crank, that seems excessive. -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
![]() -Chris
If you are taking it to High performance, THey will measure and polish and final clean for less that 100 if I remember correctly.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Cheers, Mike
I would R&R the oil line plugs. I have seen the plugs drilled out on many 911 crankshafts and there is always junk at the end of the oil line. Armando at CCR does this type of work , and he can also magnaflux inspect and polish. CCR 650-342-0568
John Dougherty Dougherty Racing Cams |
Thanks John,
I did a search for Armando and found: Armando Link Has it changed since this thread in August 2004? Cheers, Mike
I think he is much better now. He did an antique crank for a freind of mine, and it was done on time and for the price quoted. I know the problems he had with Erik were resolved and Erik recieved his crank.
German Precision (408) 747-0728 and Ollies also do the oil plug work.
