964 cams in a 930-what do i need?
im running 964 cams in my 930. do i need to use 964 cam sprockets/bolts/shims etc or will the 930 stuff work?
Andy 1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
resident samsquamch
Re: 964 cams in a 930-what do i need?
-jeff back in the saddle: '95 993 - just another black C2 *SOLD*: '87 930 GP White - heroin would have been a cheaper addiction... "Ladies and Gentlemen, from Boston Massachusetts, we are Morphine, at your service..." - Mark Sandman (RIP )
Forced Induction Junkie
Do the 964 cams have the extension on the driver's side cam for the turbo sump pump?
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
You need the later bolt and washer for the 964 cams. If your 930 is an 1982 and up, the 930 bolts will work.
The left cam also needs the scavenge pump extension as Dave mentioned. It can be added. The right side cam on an oem 964 camshaft has a power steering drive which should be removed when installing in the 930 engine. You can also punch out the plug at the end of the housing and install a seal if you did not remove the extension.
John Dougherty Dougherty Racing Cams |
sand man i think your 930 and sc cams look the same because they were manufacutered around the same time so were using the same design of hardware. Dave, im going to gravity drain my turbo so don't need to worry about the drive for the scavenge pump. John, are the cam sproket holders and cam sprockets the same on both 964 and 930 or will i need the 964 stuff?
Try not, Do or Do not
All cam sprockets, pins and holders are the same.
If you plan to gravity drain your turbo try to put the fitting as close to the scavenge pump pick up as possible. The oil pump creates a great deal of suction and will help to drain the turbo faster than gravity alone.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Cheers Henry and thanks for the tip
you can just get a set of 930 cams and have them reground, thats what I did. it didnt cost that much.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's. 2019 Silverado 6.2L |
