993 Engine Teardown pictures...
I have been posting to Rennlist some pictures of my 993 teardown. Its lots of work to repost so I thought I would post the threads for those who are interested. Its my first 911 rebuild so be kind... ;-)
DIY Rebuild Part I
DIY Engine Rebuild II
DIY Engine Rebuild III
Cheers,
Mike
Mike
97 993TT Arena Red - "Scarlett"
Old 01-07-2006, 10:43 PM
Irrationally exuberant
ChrisBennet's Avatar
Good post!
I see that you are estimating $800 to clean and micropolish the crank. Unless you are actually have the plugs removed to clean the crank, that seems excessive.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 01-08-2006, 09:57 AM
Originally posted by ChrisBennet
Good post!
-Chris
No, I do not plan to remove the plugs, just polish it up. I was also allowing time to have it measured and checked. I am sure I will use the $$$ if I am high somewhere else...
Mike
Old 01-08-2006, 12:46 PM
I checked my records; a year ago I had a 964 crank crack checked and micropolish for $135. That should help out the budget considerably!
-Chris
Old 01-08-2006, 01:51 PM
Jeff Alton's Avatar
If you are taking it to High performance, THey will measure and polish and final clean for less that 100 if I remember correctly.
Cheers
www.turn3autosport.com
Old 01-08-2006, 03:59 PM
Cheers
Thanks Jeff, that is where I think I am taking it at the moment. I am wavering a little bit...use a shop like High Performance whch do other types engines as well or ship it down to the US to a shop what does only 911's. I guess that High Performance is not a 911 specialist should not worry me since they have done a fair bit of 911 work. Everthing looks OK so far (the case will be split tonight) so the work is not that complicated.
Cheers,
Mike
Mike
Old 01-08-2006, 05:20 PM
camgrinder's Avatar
I would R&R the oil line plugs. I have seen the plugs drilled out on many 911 crankshafts and there is always junk at the end of the oil line. Armando at CCR does this type of work , and he can also magnaflux inspect and polish. CCR 650-342-0568
John Dougherty
Dougherty Racing Cams
Old 01-08-2006, 09:11 PM
Thanks John,
I did a search for Armando and found:
Armando Link
Has it changed since this thread in August 2004?
Cheers,
Mike
Mike
Old 01-08-2006, 10:13 PM
camgrinder's Avatar
I think he is much better now. He did an antique crank for a freind of mine, and it was done on time and for the price quoted. I know the problems he had with Erik were resolved and Erik recieved his crank.
German Precision (408) 747-0728 and Ollies also do the oil plug work.
John Dougherty
Old 01-08-2006, 10:47 PM
