3.2 vs 2.7 weight difference
The 2.7 in my 914/6 dropped a valve resulting in a shattered piston.
I've decided on a used 3.2 instead rebuilding the 2.7. What is the weight difference between a 3.2 and a 2.7? Both engines will use Webers and headers. The 914/901 transmission is also staying. Thanks Eddie |
I can't verify the accuracy of this chart... but I've seen it passed around frequently:
lbs-- models-- Source 400 lbs - 2.4L E, S, RS 1972-73 - Tech. Spec. book 403 lbs - 2.4L T 1972-73 - Tech. Spec. book 440 lbs - 2.7L 1975-1977 - Aichle - 911 Engines 419 lbs - 78-83 930/09,19,10 78-81 78-81 & 82-83 - Tech Spec. book 441 lbs - 78-83 930/03-08,13-17 78-81 & 82-83 - Tech Spec. book 462 lbs - 3.0L 1980-82 - Aichle - 911 Engines 483 lbs - 84-87 930/20,26 84-87 - Tech Spec. book 485 lbs - 84-87 930/21,25 84-87 - Tech Spec. book 482 lbs - 3.2L 1987 - 1988 - Aichle - 911 Engines 524 lbs - 964 89-94 M64/01,02 ROW &US 964 - Tech Spec. book 497 lbs - M64/03 RS 964 - Tech Spec. book 605 lbs - M30/69 3.3L 964 - Tech Spec. book 608 lbs - M64/50 3.6L 964 - Tech Spec. book 510 lbs - M64/05-08 993 - Tech Spec. book 487 lbs - M64/20 993RS v-ram w/o ZMS 993 - Tech Spec. book 507 lbs - M64/20 993RS v-ram w/ ZMS 993 - Tech Spec. book
914/6 2.0S with twin plug all metal body panels 19quarts of oil 4 gallons of gas and 1826 lbs (wet) |
I was the one that originally put that list together. I did u=in clude sources references.
It is certainlt fair to compare the Tech Spec. s keep in mind early engines did not included AC as standard while later ones did.
Is your car lightened so much that a somewhat heavier engine will throw off your weight ditribution? I think the grunt makes it worth it but I have only driven about 60some odd different 911's and 914's. I met a guy here in pasadena not too long ago that had a 3.2 with 993 rs cams and headers and said it was the best thing he ever did. When he took off out of the school parking lot it was like seeing the heli's come over the beach in appocalypse now. Scary fast but badass!
74 911s neverending story. two feet and a jetta for now. |
Bill,
that list rocks! brant
Air Medal or two
I am thinking the numbers are no where correct for the 2.7......
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
brant
Air Medal or two
lots lighter....I am not a big bad strong dude and can lift the whole thing up....well not far,..... but i am guessing here 300 tops that is on the bench,,and I know the dif between 400 and 300 hundred is alot..one is un bugable the othere is doable
wow..
I would find that hard to believe. not saying your not telling the truth, just that I want to hear more about it. were you lifting a long block? I'd love to hear more input, because I know that there was no WAY my 6cylinder was 300... and I've always heard that ALL 6cylinders were 400up. I hope your right though brant
Air Medal or two
hmm well some here knows for sure,,,,I cant belive its 400, rensport or someone has a list of everthing (what weighs what)....al I know is 400 is hard to shove around, 300 is ez
I once saw someone post a pallet shipping weight of a motor that was less than 400. but I dismissed that, because once I shipped a motor and rather than actually weighing it when I dropped it off, the guy at the counter asked me how much the pallet weighed..
so I dismissed the guys comment, since he was only reading a shipping company statement instead of a tare tag. bump.. someone must have more experience on this. brant
The car was down to 2040lbs with the 2.7. It still needs a lot of lightening to get down to Brant's weight of 1850!
The goal was to get the wieght under 2000lbs. I'm thinking the major weight difference should be the aluminum case versus the magnesium case. I'm sure the 4 bearing cams, and larger pistons/cylinders and aluminum intake also add a few pounds here and there. An increase of 40lbs seems reasonable. I'm expecting a power increase of about 40hp. The 2.7 CIS engine with Weber 40s and headers was probably making about 180 hp (it was pretty tired so most likely not even that). The stock 3.2 with Weber 46s and headers will hopefully make 220hp. The power increase will be more than 15 percent (with driver) and the weight increase will be less than two percent. I think the performance difference it will be noticable. Thanks Eddie |
Air Medal or two
me too, I dont know for sure what mine puts out the lil gravity thing (that you put in the windshield) says over 180...... but it sure flys
I think its gonna fly Eddie!
You should be able to get 250 easily with your engine. What are you doing for ignition?
-Andy
72 Carrera RS replica, Spec 911 racer |
Stage I (get it running):
Ignition: points type distributor and permatune (from the 2.7)with 3.2 motronic drive gear. Induction: 40 IDA3C (from the 2.7) Exhaust: Bursch 1 5/8 headers and two in/two out OEM muffler (gutted) Stage II: (most likely later this summer) Ignition: early istributor with pertronix and permatune (from the 2.7)with 3.2 motronic drive gear. Induction: Weber 46 IDA (currently working on a trade) Exhaust: Bursch 1 5/8 headers and SuperTrap megaphones Stage III: the future will tell ... Anyone willing to trade a beautiful set of Weber 40IDA3C for a set of 46IDA + $$$ Thanks Eddie |
I'm guessing its slightly heavier or equal to the 2.4T (2.7=CIS, T=cast iron cylinders), but 20 lbs lighter than the 3.0. When Porsche went from a mag to alu case the weight went up 20 lbs.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
You'll notice the source for the 2.7 #?
it was only included because I didn't have a 2.7 spec book handy at the time.(still don't)
