gasket upgrades 3.0l sc
What kind of kind of Gaskets whould you recomend for my 3.0l sc turbocharged? are the head gaskets simular to 3l turbo? other gaskets that i could use? any links where I can by sylider\crankcase shims 1-1,5mm?
Other upgrades that I should think about? 993tt cylinder head studs\arp? ++++??
-92 964 C4
- 79 930 "ruf" 380whp, K27, andial IC, Headers, electromotive hpv.
- 88 "gt2" (project)
Old 01-17-2006, 09:13 PM
Nobody want to coment??
what about cylinder head sealing on sc? are they good for turbocharging or should I use copper rings?
will be thankful for all possible upgrades i can make to my 3.0l sc for more HP......
-92 964 C4
Old 01-21-2006, 12:43 AM
That's a tough call. I'm assuming that your cylinders are stock? Alusil or nikasil? What amount of boost? I can't comment on the functionality of the original sealing ring on the SC and it's performance with the turbo, but a set of ARP head studs would be a great option, since you asked. If you want to go with a larger bore to get you to a 3.2, you'll want to just go for new cylinders, which leaves you with a plethora of sealing options.
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
Old 01-21-2006, 06:17 AM
Don't know if i have nikaslil or alusil but if I have alusil I'll go for 3,2 big bore's. Boost:high as possible... :-) I whant's tips how to make the engine compatible with higher boost\hp... head gasket's. studs, bearings, camshaft, valves, valvespring etc. etc... and for how mutch boost\hp eatch mod's will do...
f. eks; head gasked 3l sc - good for 1 bar boost
orginal studs - up to 0.5 boost...?
993 studs - up to 1 bar boost??
-92 964 C4
Old 01-21-2006, 10:14 PM
