Try not, Do or Do not
The pistons in questions are Turbo pistons. A good rule of thumb is make the valve pockets only as large as they need to be.
These valve pockets will handle most any turbo cam. BTW: Here in the US, Perfect Bore cylinders cost more than this complete P&C set. Cheers
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
What year motor are those cylinders going on? Would these cylinders also have these compression rings on them for say an '89 which has no gaskets?
resident samsquamch
The parts that I posted pictures of are going in my '87 930...as to the other pictures that might have been posted - no idea.
-jeff back in the saddle: '95 993 - just another black C2 *SOLD*: '87 930 GP White - heroin would have been a cheaper addiction... "Ladies and Gentlemen, from Boston Massachusetts, we are Morphine, at your service..." - Mark Sandman (RIP )
resident samsquamch
Granted this is my first experience with Henry's cylinders (and the JE pistons for that matter), but you really can't beat the price! Hell even the used (replated Nikasil) cylinders from EBS are more! These things are brand new. Henry offers a pretty stout warranty/guarantee on the engines that he builds, and I'm confident he's using these cylinders in his own engines! So what the hell...I rolled the dice, we'll see!
I really am curious about that "gasket" on your cylinders. I bought a set of pistons and had the cylinders replated through EBS. I questioned them about the need for any additional machining or need for a gasket where it mates with the head and they said that there was no need. I have been supercharging my motor and will do so again when I have completed the assembly.
resident samsquamch
Well you have to remember, on my engine - a stock 911 Turbo - there is no gasket between the head and cylinder. A common option was to run the Nirosist sealing rings. However, using superior ARP, Supertec, Performance Developments, Raceware, etc head studs also helps keep these things from lifting as bad as that Dilavar shiz!
The 3.2/3.3 cylinders used a .0015-.003" taper across the sealing surface rather than a sealing ring, if you were wondering. With a good set of studs and stockish boost, that's plenty sufficient to seal the cylinder off. As the bore increases, the "real estate" for sealing the cylinder and head off shrinks and typically, those going that route also up the boost, and the two together require additional procedures for sealing the cylinder and head off. Performance Development and CMW Motorsports (there are others too) use a double interlocking sealing ring that indexes both on the cylinder and head and I have used both with excellent results.
Charles Navarro President, LN Engineering and Bilt Racing Service http://www.LNengineering.com Home of Nickies, IMS Retrofit, and IMS Solution |
thanks.
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
resident samsquamch
