resident samsquamch
My new 98mm Ps&Cs from Supertec
Here's a couple of pictures of my new pistons and cylinders. The pistons are custom 98mm JEs and the cylinders are the new ones that are made for Henry Schmidt...I think they are QSC. These things look too pretty to use.
Henry, On that large sealing ring (head gasket) is there any type of groove that needs to be cut into the receiving end of the cylinder head? Any special instructions? Any special deck height adjustments that need to be made for it? Also, on the pistons do you think I'll have any clearance issues using higher lift SC cams? You probably won't be able to answer that one as we won't really know until I do the check.
-jeff back in the saddle: '95 993 - just another black C2 *SOLD*: '87 930 GP White - heroin would have been a cheaper addiction... "Ladies and Gentlemen, from Boston Massachusetts, we are Morphine, at your service..." - Mark Sandman (RIP )
Hey sand man,
I just installed a set of 98's with JE pistons too, but on my '89 there are no head gaskets. Was that head gasket always there was that done by Supertec? |
resident samsquamch
These are evidentally a "new" cylinder that are being made exclusively for Supertec. Honestly, I had no idea about the gasket until the order arrived. I just don't want to screw anything up. If something needs to be machined, now is the time.
I'll be interested in hearing from Henry too since this may be a problem area that is being addressed on these engines.
resident samsquamch
I think it might be somewhat derivative of a "Nirosist" sealing system. However, that typically involves cutting a groove in the head. I don't wan't to speak for Henry though. All I can say is they look first rate!
I would rather be driving
I suspect these are marketed toward an SC owner that already has the cylinder gasket. I am sure Henry will chime in with a correction.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
I guess I assumed that these were from sand man's '87 930. Probably are from an SC. Whew, thought I forgot something when I put mine together last weekend!
3.4 Bigger is better
They are a copper sealing ring from earlier Porsche design. I am going to be ordering mine soon. I'm sure Henry will chime in and explain more. I'm jealous that I don't have them yet..
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport |
resident samsquamch
I hope they're compatable with a turbo environment...
Try not, Do or Do not
The cylinders are designed to install as they are. The additional machining.
The cylinder was an extension of two different designs. The early sealing CE ring used by Porsche in the early Nikasil cylinders and the graphite gasket of the 964. We were looking the seal the cylinder better than both and weren't happy with no gasket at all. We were using Nirosist sealing rings and noticed that they leak almost as bad as using nothing. These gaskets when used with Supertec head studs show no movement or leaking under the most severe conditions. Welcome to a new era of Porsche performance.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
resident samsquamch
EXCELLENT! Anything special I need to know about torque values? Can they be torqued more than once? For instance can I torque them in a "dry assembly mode" to check for clearances and then break them down and perform final assembly, or will this ruin the crush properties of the copper ring?
They can torque them over and over until heated. When they heat with engine temperature they take a set. After the engine has been run we like to replace them.
This does not mean you have to replace them after a certain mileage, it means that on the next rebuilt replace the gaskets. On turbo applications we torque the Supertec head studs to 32lb. Consult other manufacturers for their recommendations.
Turbo cylinder pressures facilitate the need for additional sealing and quality head studs. In the 91 Porsche turbo, you will find steel head gaskets and we quite often see them deforming from heat and creating a leak that may not have form if not for the gasket. We have not seen this with our cylinders.
How much are they? I will be needing a set for a SC to make a 10.5 to 1 3.2 SS
1983 911SC 1977 911S "parting out" |
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 01-18-2006 at 07:08 PM.. |
I hate freight charges
Wow!! the price is very reasonable too.
Henry, are there any plans to market different compression ratios through your company or would I have to buy the cylinders from you and contact JE for a shelf/custom piston??
Tom 78 911SC SC to 73RS imposter SCWDP crew #50 and 51 1969 Camaro "The new project"
84mm, 86mm, 90mm, 92mm, 95mm, 98mm, 100mm, 102mm
Any compression ratio you choose.
![]() Do the cases on my 78SC need to be bored to fit the 98's??
Yes I would like to know this also?
Those valve pockets look similar to the 98mm Max Moritz set up which will only run a relatively mild cam, unless additional clearance is made.
![]() I ended up buying new a B&P set for my SC motor. 98mm J&E 10.3.1 CR with new barrels from Perfect Bore, here in the UK. These will be running S cams. ![]() Alan.UK |
