Ever jump a Porsche?....
78targa's Avatar
Thumbs down Tape or block off everything!!!
I figured I would share this with everybody. I was smart and plugged all of my intakes as I was working on the engine with the manifold removed.
A nut got stuck in my socket so I shook it out. Can you believe that after arcing a foot to the left and maybe a 3 or so foot drop, a 13mm nut dropped straight into the breather hole?!?!?!?! It barely grazed the sides as it dropped in and immediately bounced into the bottom (inside) of the case.... That stupid hole was even pointed in the other direction!
Luckily I am in thew process of tearing down the engine completely so the case is coming apart and everything, but WOW. I coudn't have done that in another million tries. What a good lesson that was. Thought some of you guys would get a kick out of it.
Here is a picture showing how and where I was holding the socket. See the breather? It went in..."nothing but net"...
Casey
Road-rally, Targa Newfoundland junkie!!!
1969 RSR 3.4L PCA class GT-3 (in progress)...1800 lbs and dropping
Thinking of driving in TARGA NEWFOUNDLAND? Contact me and I can help answer your questions. The event is awesome!
Old 01-19-2006, 07:49 PM
Wer bremst verliert
JohnJL's Avatar
SWISH!
Go and buy a lottery ticket...
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 01-20-2006, 03:57 PM
gestalt1's Avatar
thats a special feeling. when you get the case open post a photo showing where the nut's temporary home was.
BMW 128i
73 rsr clone - sold
68 912 project to become 911r (almost done!)
Old 01-20-2006, 05:11 PM
Actually you might be able to fish it out of the bottom with the oil sump plate off. If not I wouldn't worry about it. It can't get sucked into the oil pump because of the screen and I can't think of any other damage it could cause. I would pull the breather off just to make sure it wasn't sitting in the top of the case inside the breather.
-Andy
Old 01-20-2006, 05:34 PM
Wer bremst verliert
JohnJL's Avatar
It could get in all kinds of trouble if he doesn't fish it out/crack the case...could rest on the case and get hit by the rod cap on the way down, get pulled into the chain and lodge between chain and sprocket and stop it/snap a chain, could bounce up and get lodged between the intermediate shaft gear and distributor gear....bad things all!
Old 01-20-2006, 11:12 PM
78targa's Avatar
Well, It is a 3.2 case so no sump plate to fish it out. as for resting under the breather plate on the ledge...nope it shot straight in and bounced to the bottom of the case.
As I said though, I'm lucky I am in the process of tearing the engine completely down. If it was going back together...that would suck. Definately an item you wouldn't want floating around in the case. Even a washer could/would do irreparable harm.
It serves as a great reminder how important it is to block off everything.
Casey
Old 01-21-2006, 07:10 AM
You're right about the bad possibilities if the nut is in the area of the crankshaft or on one of the webs where it could hit the crank. It would be safe only if you were sure it was in the bottom by the oil pump. I doubt it could get to the intermediate shaft or chain area as the case has a barrier there.
I was not exercising due diligence before on saying not to worry about it.
-Andy
Old 01-21-2006, 10:09 AM
adomakin's Avatar
just finished installing my pistons/barrels/heads/cam housings and on the last but one piston I managed to drop a wrist pin circlip into the engine. had pretty much everything covered up including the spiggot hole directly below the piston that i was installing. it still managed to sneak its way in. I alsmost had a seizure. everything went in slow motion-----nnnnoooooooooooooooo!!!!!!---------------nnnnottttttt insssidddde thhhe caaaaaasssse!!!!!!!!!. but inside it went. I turned the engine upside down and it fell out. thankyou lord.
Andy
1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Old 01-30-2006, 12:13 PM
mppickett's Avatar
whew!
Old 01-30-2006, 01:29 PM
