andrew15's Avatar
Crazy previous engine rebuild
I just took apart my '66 donor engine this past week and found a couple of suprises.
On the good side - 67S Heads instead of the standard ones
On the questionable side: previous rebuild with 5 'S' Pistons + 1 906 Piston!
I wouldn't mention it, but last year I took apart a previously rebuilt 2.7 engine with 5 Mahle Nikaisl pistons and one KS Alusil!
It's odd - I just don't see how mistakes like mismatched pistons could be made by someone rebuilding an engine
Regards,
Andrew M
Same engine:
1970 911E - track / weekend car
1970 911S - under restoration
1986 930 Slant Nose - fun car
Current used parts for sale
Old 01-21-2006, 06:51 PM
Jandrews's Avatar
wow! I often wondered how something like that would run! Those pistons have to weigh different amounts, have different CR, everything!
Sheesh...
JA
John
- '70/73 RS Spec Coupe (Sold)
- '04 GT3
Old 01-22-2006, 07:26 PM
stevepaa's Avatar
Reminds me of my 1969 912. When I went to rebuild it, it had a big bore kit and a 67 crank. Rebuilt back to original with 69 crank and Mahle P&Cs.
steve
old rocket inguneer
Old 01-23-2006, 07:45 AM
Did it have a motor miester sticker anywhere on it?
1983 911SC
1977 911S "parting out"
Old 02-13-2006, 09:20 PM
304065's Avatar
Actually the MM touch would be rebuilding your 906 with one 901 piston.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 02-14-2006, 11:44 AM
andrew15's Avatar
All of the internal parts measured well within spec, so MM has probably never been near it
AM
Old 02-14-2006, 02:39 PM
Jeff Alton's Avatar
I doubt that the piston fiascos were mistakes. My guess is those were what the builder had on hand..... Any chance you got both of those motors from the same person?
Cheers
www.turn3autosport.com
Old 02-14-2006, 03:18 PM
andrew15's Avatar
Thats the odd thing - both motors were from totally different places -one local to Calgary, the other from California.
AM
Old 02-14-2006, 03:25 PM
Jeff Alton's Avatar
Wow, very odd. On the other hand, you now have a 906 piston for the shelf!
Cheers
Old 02-14-2006, 03:43 PM
