bavaria911's Avatar
Oil pump price ?
Gents,
I have obtained a GT3RS (996) oil pump and would like to know the value of the pump. It is from a motor that only had 8,000 Kms. Motor was torn down to part out, car was in a reck. It is absolutely in perfect order w/o any wear marks on the inside gears or shafts. I will be tearing my 2.4 motor down and either machine my case to fit this pump or sell it and use the money for other areas needing attention.
Just looking for a value and make me an offer if you must
Vr,
Bavaria
Bavaria911
1970 911T w/ 2.4S
1971 911T Targa w/ 2.2
RG Member # 818
Old 02-04-2006, 03:11 AM
pump.
hello there.
I'd give 350 for this if you want to sell.
kind regards
david
Old 02-04-2006, 05:49 AM
bavaria911's Avatar
My min price is $450.
Thanks,
Bavaria911
Bavaria911
1970 911T w/ 2.4S
RG Member # 818
Old 02-04-2006, 11:43 AM
Jeff Alton's Avatar
Well, then I guess you answered your own question, it is worth 450!
Cheers
www.turn3autosport.com
Old 02-04-2006, 11:45 AM
bavaria911's Avatar
Yup!
I sure did. I'll sell the pump to someone and they can save $300.
I'll call Henry...(or Henry can read this post) and ask what the machine work is and the cost to install the pump into a 2.4 case. Yes, I know it's an over kill, but since I have it....
Thanks,
Bavaria911
Bavaria911
1970 911T w/ 2.4S
RG Member # 818
Old 02-04-2006, 11:50 AM
Jeff Alton's Avatar
I agree, if you have it, may as well use it!
Cheers
Old 02-04-2006, 11:55 AM
BReyes's Avatar
Let us know what you find out about fitting it.
Good Luck!
Bernard
Old 02-04-2006, 04:33 PM
Pump fitment
We have installed the GT3rs pumps in early alum 2.0 cases thru 964 cases, the webbs for the mains need machining and the floor of the case needs to be checked for room where the additional scavenge picks up, not a big deal with the proper equip.
Mike Bruns JBRacing.com
Old 02-05-2006, 07:28 PM
bavaria911's Avatar
Thank you for the information. After consulting with our host and talking to a friend, I'll machine the case and use the GT3RS pump.
Thanks to all,
Bavaria911
Bavaria911
1970 911T w/ 2.4S
RG Member # 818
Old 02-05-2006, 11:53 PM
Try not, Do or Do not
Henry Schmidt's Avatar
The machine work to install the GT3 pump in an early engine is fairly simple. It can be done at home with a die grinder or Dremel tool.
Call and I'll tell you what you need to do.
(760) 728-3062
Cheers
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 02-09-2006, 05:42 AM
