-   -   After a long time, it has begun! rebuild yay (http://forums.pelicanparts.com/911-engine-rebuilding-forum/267048-after-long-time-has-begun-rebuild-yay.html)
Porschekid962 04-21-2006 12:13 PM
Its gold heat reflective foil. I got it from hrp on the web. Awesome stuff but a pain to get on right.
Porschekid962 04-23-2006 08:59 PM
more stuffs...
the induction
http://forums.pelicanparts.com/uploa...1145850866.jpg
http://forums.pelicanparts.com/uploa...1145850898.jpg
crazy powdercpoated color...
http://forums.pelicanparts.com/uploa...1145850938.jpg
muffler from ben, pre finishing and without tips welded on, for 993 heat exchangers.
http://forums.pelicanparts.com/uploa...1145850991.jpg
and my artsy desktop pic
http://forums.pelicanparts.com/uploa...1145851098.jpg
fitted fuel filter and accumulator, cut braided hose to length, mounted new pump, ripped out more wiring, clutch cable, speedo cable, ran some power lines and wiring. should have parts back this week and start putting an engine together.
Jeff Alton 04-23-2006 09:34 PM
Comming right along! looks good!
Cheers
Porschekid962 04-29-2006 10:32 PM
Ok so on friday headed down to the machine shop. Cleaned out all oil galleys in the case, washed it about 5 times. Chased head stud threads. Chased the threads for the cam tower cover studs as well, talked shop, checked out a 935 throttle body that was hanging around and did some more cleaning. John balanced the rods and we did some other clean up and little tricks here and there. Still waiting for the new valves to show up and thats it. So sunday will be spent finishing the wiring for the ecu and engine harness, possibly pick up the engine parts but most likely that will be monday. Maybe get the trans installed. Thats really it for now, nothing too exciting I know. Did get a chance to look at some internals on some awesome factory race motors though, pretty neat stuff.
mppickett 04-30-2006 06:56 AM
Great looking set of parts and engine bay. You are doing a super job! http://pickettweb.com/icon/burnout.gif
shbop 04-30-2006 10:48 AM
Dear Santa, I've been pretty good all year--well maybe a couple of slips here and there but, if you could just slip one of those cool Jenvey induction units under the tree. I promise.........
Porschekid962 05-07-2006 10:40 PM
picked up the parts from machine shop...
Well tried to get the bottom end together this weekend but federal mogul decided to put the wrong bearings in the right box so I couldnt put the rods on the crank. Started putting the clips into the JE pistons and what a bear that can be. There must be a better way! Got most of them on but I need to order some more because one went flying around the garage, got the rings on the rest. Popped the oil pump and intermediate shaft into the case with the main bearings, cleaned up the distributor hole for the plug. Thats really it just waiting for new rod bearings to show up.
http://forums.pelicanparts.com/uploa...1147066502.jpg
http://forums.pelicanparts.com/uploa...1147066538.jpg
[img]http://forums.pelicanparts.com/uploads7/IMG_00131147066570.jpg[/
img] http://forums.pelicanparts.com/uploa...1147066645.jpg
http://forums.pelicanparts.com/uploa...1147066696.jpg http://forums.pelicanparts.com/uploa...1147066722.jpg
http://forums.pelicanparts.com/uploa...1147066751.jpg
and the neat little heater adapter pieces.
more to come as things move along. cheers!
Porschekid962 05-07-2006 10:51 PM
more...
http://forums.pelicanparts.com/uploa...1147066983.jpg
http://forums.pelicanparts.com/uploa...1147067005.jpg
LN stuff is great!
http://forums.pelicanparts.com/uploa...1147067036.jpg
notched the screwdriver to aid in getting the pin clips in a bit easier, doesnt work all that great, did 4 without problem but the last 2 are kicking my ass.
http://forums.pelicanparts.com/uploa...1147067103.jpg
well hopefully things go quickly this week. i want to have the bottom end together asap, then p&c's, top end and timing. engine tin with the cutouts for lower plug wires, fit the fiberglass shroud, final fit for the engine wire harness, stick the trans in the car, hookup some more wiring, more wiring, a little plumbing and other odds and ends.
Mr9146 05-08-2006 02:47 PM
It's always nice to see progress, isn't it?
Things are looking good.
jbell959 05-08-2006 02:48 PM
Those clips are a real pain. I made a simple tool that made it much easier. Take a look at this thread.
http://forums.pelicanparts.com/911-engine-rebuilding-forum/258950-je-piston-pin-cilps.html?highlight=clips
Good Luck!
Porschekid962 05-08-2006 04:16 PM
Thanks a ton for that link, I remembered there was something somewhere about this. I was wondering if it really was possible to install the pistons to the cylinders and then connect to rod to the piston and now I see it can be done! I hope my rod bearings showed up today hopefully some progress can go on. I did have some time to swing by my old shop and fab up a bracket to mount on the trans and take a cable pull from the bellcrank to actuate the crossbar linkage on the Jenvey's.
jbell959 05-08-2006 04:38 PM
No problem - good luck with the rest of the build. Sounds like a great engine.
Jeff Alton 05-08-2006 09:41 PM
How about a pic or two of the bracket for the throttle?
Looks good by the way!
Porschekid962 05-08-2006 11:26 PM
pics of progress
jeff i knew youd want that sooner or later. here goes and a little progress.....
http://forums.pelicanparts.com/uploa...1147155005.jpg
http://forums.pelicanparts.com/uploa...1147155046.jpg
http://forums.pelicanparts.com/uploa...1147155164.jpg
The only other thing I am going to do is shorten the bellcrank arm and move the outer lever inboard just next to the inner arm. Then its drill a hole in the upper plate, route the cable and call it a day.
Now motor pics, got the bottom end together tonight, tried installing one of the JE's into the LN cylinder and its a bit tricky because the base of the LN has a chamfer towards the inside of the cylinder. I think I will just tack weld a small bit of metal to the piston ring compressor band to keep it from sliding in with the piston.
http://forums.pelicanparts.com/uploa...1147155412.jpg
I was really happy with the way the plated pieces turned out. Really happy we did it especially the through bolts.
http://forums.pelicanparts.com/uploa...1147155458.jpg
http://forums.pelicanparts.com/uploa...1147155531.jpg
this was my first time using 1104, yamabond I hear its the same, sealant. I really like the stuff, it went on easily and just a tiny bit squeezed out all around the case. I was very happy with how uniform and minimal it was. Hopefully it will always look this clean on the bottom.
http://forums.pelicanparts.com/uploa...1147155570.jpg
http://forums.pelicanparts.com/uploa...1147155639.jpg
t951 05-09-2006 06:11 PM
wow
no need to say more.
Jeff Alton 05-10-2006 04:28 PM
Looks good, thanks. I will be interested in watching your progress, you are a little ahead of me! Got the fuel lines all figured out yet? Are you using a regulator?
Cheers
Porschekid962 05-10-2006 11:22 PM
a wee bit o progress
Fuel lines are pretty much figured out. I just need to have the regulator show up so I can plumb it in thats all, oh and replace the pump and other little things. I got the whole left side on the engine tonight, all the cylinders are on on the right, just put on some heads and cam towers over there tomorrow and start timing.
Deck height checked out to be withing what I like, what my machinist likes, what some friends like that build these motors as a means of making a living, what I have heard from others that are reputable so some might think its a smidge low but I checked everything. Deck height checked on 4 cylinders, piston to valve clearance checks out as well, piston dome to head surface checks out too.
So things are picking up steam still going slower than I would like. Hopefully this weekend I can have it buttoned up and start fitting the shroud, get the intakes and exhaust on, get it in the car along with trans to finish wiring.
Oh and modded the oil breather plate and mounted the oil temp sensor there. Looks like it belongs.
Cheers all, some pics, fun and some goofey.
http://forums.pelicanparts.com/uploa...1147328275.jpg http://forums.pelicanparts.com/uploa...1147328287.jpg
http://forums.pelicanparts.com/uploa...1147328317.jpg
http://forums.pelicanparts.com/uploa...1147328344.jpg
couldnt resist seeing how it will look.
http://forums.pelicanparts.com/uploa...1147328369.jpg
new valves, seats, bases, springs, retainers, seals and guides. valves and guides are from SI which make some awesome stuff like the finned 935 style valve guides that I got and those valves that happen to be awesomely priced with tons of cool features lol
http://forums.pelicanparts.com/uploa...1147328408.jpg
so need to figure out some wiring and get back to it.
kstylianos 05-11-2006 05:13 PM
Porschekid,
Looking good so far. Most impressive.
Just an FYI: Don't think the oil temp sensor will work in that location. I believe that the sensor needs to be submerged, or at least in the path of the oil. In the breather loaction, at best, it'll receive some oil splatter, but mostly warm air giving innacurate indication of true oil temp........don't know if you are planning on using its input for EFI, or just for the dash gage.
Good luck with the rest of the build. Looking forward to updates.
Jeff Alton 05-11-2006 05:24 PM
Would it be better placed in the chain box cover?? Any other ideas about where to install it?
kstylianos 05-11-2006 05:33 PM
You can get creative, i guess, but I'd say just keep it in the original location, in the path of the oil to the tensioners/cam towers. Whatever you do, just make sure its either in the oil path, or submerged.
