3.0L P&C Identifiation
I have obtained a P&C set for a 3.0L SC with the following numbers on them:
pistons: 95L67 C021 cylinders: 95ZNW2 Can anyone tell me what these numbers mean, what car they came from and what the CR is?
Erk ![]() PCA Member restored 79 911SC Euro green, mean and ready to rock |
I have a set of Nickasils from a Euro 3.0l engine that has the 95ZNW2, except that it has a 1 between the N and W. Including a picture. Just checked the number on the pistons... I have 95L70 ++ C021 with hi-comp Euro pistons. Also giving you a picture. Do they say Mahle on yours? Nickasils have 11 fins. The inside of your piston should also say Mahle if they are. Hope this helps... Lou
'76 911 "Moneypenny" daily driver '74 911 "JLo" IROC DE Car '03 CRV, '02 Jeep Grand Cherokee '03 Holiday Rambler Admiral SE, 30ft, 8.1l, 340HP, 455Ft# http://www.nicotra4.hpshare.net/BasketCaseMotorsports/ |
interesting, I guess the last number hs something to do with the CR. Mine ends with a 1 and I know thery are 8.5:1. I have a used set to go back in, and the # ends with a 2. Looks kike a 9.3:1 set from an 80s or later SC. The set that I have looks great, however the bottom piston skirt dimension is just under the recoomended wear range. Think that these will be ok?
