I like Orange
Cookie Porsche's Avatar
Vibration Damper and L/W Flywheel (993)
We are having an interesting discussion with a customer and I need a little input.
His 993RS is fitted with the non-damper l/w single crank pulley. Before he took delivery the engine was rebuild by Porsche and a l/w flywheel setup (non DMF) was fitted.
The question now is - should one fit a vibration damper pulley on the front of the crank to compensate for the new l/w flywheel setup?
We have several 964/993 engines running the Clubsport type l/w flywheel, and sofar have had no problems.
Would there be a difference btw a road and a pure track setup? i.e. use vibration dampers only for a road engine?
Regards
Tom
“Rules are meant to be interpreted…”
http://www.cafe9.co.za
Old 02-22-2006, 09:28 PM
Tom,
Check the post "New problem with 3.6 case" on this page. Lots of great info.
DOUG
'76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's.
'85 911 Carrera, stock, just painted, Orient Red
Old 02-22-2006, 09:43 PM
I like Orange
A case of premature posting... Just read that thread and you're right - good info.
Tom
Old 02-22-2006, 10:04 PM
Bill Verburg's Avatar
No, they serve unrelated functions, the 964 used a harmonic balancer to address some issues specific to the 964 crank, a 993 does not have those issues.
The dual mass flywheel was intended to address transmission gear rattling issues(as was the original rubber center clutch)
no, the difference is between 964 and 993
993 Cup cars did use the harmonic balancer but I believe that was because of production line expediancy related to the early date of their manufacture
Bill Verburg
Old 02-23-2006, 02:20 PM
