andrew15's Avatar
Are these cylinders junk?
I have 3x 95mm nikasil cylinders that I believe are junk. They all have a 'chunk' out of the lower edge from some debris in the engine - ie a broken piston from another cylinder
Anyway - these are junk right? I just want to make sure before they make a loud noise in the garbage bin.
Regards,
Andrew M
1970 911E - track / weekend car
1970 911S - under restoration
1986 930 Slant Nose - fun car
Current used parts for sale
Old 02-18-2006, 10:24 PM
Autobahn Garage
If you grind that area smooth I think you can still use them. The rings never get thet close to the chipped area so you should be OK. Please don't flame me for this GUYS
T Tanner
76, 911s w/ Webers
76, 914/4
57, Speedster
Old 02-19-2006, 05:26 AM
cylinder?
The damage shown on the bottom side of your cylinder is not an issue. The rings come down only as far as the where that dark ring starts.
1986 911 Turbo
Old 02-19-2006, 05:52 AM
Irrationally exuberant
ChrisBennet's Avatar
I might add that you'll want to check to make sure they weren't banged out of round when they got wacked.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 02-19-2006, 08:29 AM
id911T's Avatar
If they're still round, I'd just clean up the nick and put them back into service.
Stephen
GruppeB #906
1970 911T
Old 02-19-2006, 12:05 PM
Why don't you take them down to Ollies and get them moon cut? Apparently you have to watch on Nikasil because it can start to chip off (or so I am told). If the moons will not be where the chips are I am sure that they can take a bit off the bottom anyways to get rid of the rough edge.
Cheers,
Mike
Mike
97 993TT Arena Red - "Scarlett"
Old 02-19-2006, 04:51 PM
Porschephd's Avatar
They should be fine but have them checked. It is not uncommon to relief cut the bottom for better windage. What caused the nick?
Stephen
94 3.6Turbo 6-speed AWD
Old 02-19-2006, 05:26 PM
