Banned
Any updates on the outcome of this rebuilt???I like how you this this,very methodical!!!
Old 05-27-2007, 11:28 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #121 (permalink)
CBRacerX's Avatar
Been driving the car around regularly, did another oil change (still Dyno for now) and getting ready to swap out the stock v-ram chip for the RS version. Runs great!
Chris
https://dergarage.com
‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8
Old 05-28-2007, 07:54 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #122 (permalink)
Banned
Did you took care of the oil leaks??
Old 06-14-2007, 07:37 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #123 (permalink)
CBRacerX's Avatar
Nope, not yet - I figure there are plently of cold and wet months for me to do that
Chris
Old 06-14-2007, 07:43 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #124 (permalink)
Banned
Well, that sucks!!
Old 06-14-2007, 08:01 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #125 (permalink)
CBRacerX's Avatar
Well, that sucks!!
Gee - I guess it would be more fun to pull and re-seal the motor (which for me and my work/family life would be at _least_ a month) instead of driving every day with the windows and sunroof open and enjoying the 3.8 puuuush from back there....
Chris
Old 06-15-2007, 04:30 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #126 (permalink)
Banned
Well, as long the oil is not dripping on a hot surface (eg. headers)it won't be that much of a pain!
Old 06-15-2007, 05:25 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #127 (permalink)
kirkf's Avatar
My car is still leaking at the thermostat housing. I went in once to fix it and I thought I had it all sealed up, and then it started leaking again. I havent gotten back to it again yet.
I am dropping the engine next week to start the supercharger install so I guess I will look at it then.
Kirk
1989 911 Carrera 4 (964)
Old 06-18-2007, 07:02 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #128 (permalink)
up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
My understanding is 3.8 pistons/cylinders drop onto a 3.6 case? Or does the case need to be bored?
Thanks,
Scott
Scott Kinder
kindersport @ gmail.com
Old 01-25-2008, 06:08 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #129 (permalink)
There are slip-fit and machine in variants of the 102s; traditionally, then you can go to 104s at the larger 109 case register.
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
Old 01-25-2008, 06:14 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #130 (permalink)
CBRacerX's Avatar
Thanks,
Scott
In this case I used the machining required version, which is generally acknowleged to be stronger.
Chris
Old 01-26-2008, 07:10 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #131 (permalink)
ianc's Avatar
Great thread! Really enjoyed reading it.
A little vid or two might round it out nicely, don't you think?
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 01-31-2008, 08:02 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #132 (permalink)
CBRacerX's Avatar
Status Update: Recently reinstalled this engine after tearing it down to seal the base of the cylinders with Threebond 1211, install a new flywheel seal and new case thru bolt o-rings. I went with the Wayne book approach of using a very small amount of sealer (1211 in my build) under the case thru bolt washers and nuts/bolt heads. Also installed a set of Imagine Auto lower valve covers. Pleased to report that there are no leaks!! Whew.
Also installed some software to try and get the engine running closer to potential - Steve Wong provided a baseline chip (3.8 RS I think) and I will be getting a dyno run done to complete a custom chip. But even the baseline chip is much better than the ROW V-Ram programming I was running (that I never really pushed hard).
Chris
Old 05-28-2009, 01:54 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #133 (permalink)
wax105's Avatar
Keep us posted on the dyno run Chris! Congrats...
74' Coupe 3.6 Track Car
VW passat avant 4motion 1.8T
CRG Kalifornia 125Rotax (Sold)
Old 05-29-2009, 05:31 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #134 (permalink)
0396's Avatar
Congrats!
Old 07-13-2014, 01:35 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #135 (permalink)
Ten years ago now. Looking back, was it worth it to go 3.8? I might be in line to do the same. Also, how many hours did you spend on this project DIY?
Thanks,
Lou
Old 03-25-2020, 06:29 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #136 (permalink)
CBRacerX's Avatar
Thanks,
Lou
It was a great build and I would do it again anytime. Engine ran great (I have since sold car). A full tear down and rebuild is about 90 hours of labor depending on the options pursued.
Chris
Old 03-25-2020, 08:22 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #137 (permalink)
