resident samsquamch
sand_man's Avatar
Dow Corning 111 on engine o-rings
I was able to source and purchase a tube of Dow Corning 111 that I plan to "lube" my green Viton through-bolt o-rings with. Can this Dow Corning product be used with all of the other o-rings in the engine: oil pump, oil return tubes, cam shaft backing plate, oil cooler, etc.? I know that motor oil is often used on o-rings, would the Dow be better? Any known ill effects from using it on other o-rings?
Thanks,
Jeff
-jeff
Old 02-22-2006, 08:27 AM
resident samsquamch
sand_man's Avatar
By the way, I've heard that the Dow Corning 111 can be hard to find in a size that's not "industrial" (huge can). Here's where I obtained mine:
http://www.waterfiltersonline.com/detail.asp?product_id=Dow_111_5oz_Silicone_Sealant
-jeff
Old 02-22-2006, 08:38 AM
abit off center
cgarr's Avatar
Here is what it says about it, I would guess so.. No. 111 Valve Lubricant/Sealant— Choose this heavy-consistency paste to lubricate valves, packing, and O-rings as well as seal vacuum and pressure systems. Temperature range is -40° to +400° F.
______________________
Craig
G2Performance
abit off center
cgarr's Avatar
You can get a 5.7 tube from McMaster for 10 bucks
Craig
G2Performance
Old 02-22-2006, 08:40 AM
resident samsquamch
sand_man's Avatar
Thanks, Craig!!!!!!!!!!! I was planning on using it on many of my o-rings, but thought I better at least ask the question before doing so.
-jeff
Old 02-22-2006, 08:43 AM
mppickett's Avatar
Jeff,
I used Dow Corning 111 on all of the seals that you mention. I'd suggest that you use it where the seal needs to slip into place. I'd suggest oil or assembly lube on the part of seal where there is a lot of movement (e.g. put a little oil where the crankshaft will rotate, put the 111 where the oil pump seals need to slip into place once, etc).
Mike
Old 02-22-2006, 11:29 AM
I recommend not using it on the number 8 main bearing o-ring or at least not using it near where the case seam will be. If some of the silicon grease gets into the seam it will keep the case sealant from sealing that area an cause a minor oil leak (as me how I know!).
-Andy
Old 02-22-2006, 11:45 AM
Irrationally exuberant
ChrisBennet's Avatar
I used it on most of the O-ring except for the case through-bolts. I just dump those in a cut off paper cup of oil and take them out as I go along.
Get the green viton through-bolt O-rings. Wrightwood makes them but they only sell wholesale. Maybe Neil can get them for you?
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 02-22-2006, 12:03 PM
resident samsquamch
sand_man's Avatar
Thanks Chris, I got them from Henry of Supertec.
-jeff
Old 02-22-2006, 12:07 PM
abit off center
cgarr's Avatar
And the thru bolt nuts go on the case side without the chamfer in the holes, I have seen books show it the wrong way before
Craig
G2Performance
Old 02-22-2006, 12:14 PM
